Dave and I have been using the hand sanding method with a block and 2000 wet and dry and then finishing up with micromesh pads up to 12000 grit. (on sprayed Ubeaut Hard Shellac)
Whilst the finish is pretty good you can still see little swales and dips if you really inspect it closely and I want to eliminate that.
I've been considering a Festool ETS 125 EQ. Expensive little number here in Oz (^$400) but the 110 volt ones in the States are only $165US and we've got a 110 volt transformer in the shed. (Dave is from Wales and all site tools in the UK have to be 110 volt for safety reasons and he bought it out with him and we forgot that we had it
![Confused :?](./images/smilies/icon_confused.gif)
I really don't want to go down the track of upgrading the compressor to handle Dynabrade air sanders and the Festool seems like a workable alternative.
Any suggestions and comments would be most welcome.
Bob
