What you doing?
- matthew
I need 1200 long and 330 wide for back, but I can deal with narrower and make up a multipiece back. backs are about 6mm thick.
For ribs, minimum 220 wide and 700mm long. ribs are 2-3mm thick.
In my wood hunts, I'll look at anything 1200mm long, or anything 220mm wide or wider. They are my magic numbers. I can always glue bits together if the wood is nice enough!
Mathew,
You may want to give Tim Spittle a call on 08 62782187. Tim makes trips to tassie quite often, as I understand most billets are converted down for guitars so the lengths are more manageable when strapping onto a pallet.
However if Tim knew what you wanted as you have described above, I am sure he would be happy to keep an eye open and save some of the odd rare defect free longer lengths from the docking saw.
- graham mcdonald
Cream Ivoriod looks pretty groovy on a tiger myrtle mandolin
and as a friend pointed out to me once, once you get ebony bindings under a finish, you may as well have used black plastic as you can't tell the difference, and the black plastic is much easier to get on!
Jim,
I would be interested to know more about the polyurethane...
graham
Jim,
graham
Graham McDonald
- sebastiaan56
Darwin Blues
The Spray Gun was promised last Friday or Monday as it had "already been ordered".Thinking I had waited long enough for the "phone call" I dropped in today to be informed that, in a tone I have heard over and over, "I am sorry but it seems it hasn't actually arrived in Australia yet and may be a month away". I got my money back and went down the road and bought one that cost $50 more but at least I have the tool for the job now.
Have been a little bit side tracked as well by a circa 1940's/50's Bandsaw project but should get some sample painting started next Monday.
hello bob
do you some pictures of your tiger myrtle OM guitar finished ?
thanks
ol
see this one with maple, in french " érable moucheté "
http://picasaweb.google.com/GuitareFred ... leMouchete#
thanks
ol
