Major internal bass repair - inlet patch
matthew
Post by matthew » Sun Sep 13, 2009 10:46 pm
When someone knocks a double bass onto the ground bridge first, the soundpost has a tendancy to shoot through the carved top, or at least crack the top badly.
Due to the pressure at this point, you can't just glue up the crack and tune the strings back up. It requires a full belly-off repair job.
This is the soundpost crack – going off in three directions. i glued this up first.
Then I carve away a dome-shaped area on the rear of the plate, almost all the way through to the varnish!
I rub pink chalk into the polished cavity, then press the pre-cut patch wood into the space. Wherever it shows pink, I remove wood, and repeat until the whole surface is contacting evenly and closely.
in the next pic you can just see the back of the crack peeping through. the belly is now about 2mm thick in the middle.
for clamping, i've improvised a miniature go-bar deck. I prefer this way to using c clamps and it allows me to apply pressure where and how i want.
The finished patch; for this lower-priced bass it'll do the trick and get the bass back playing again.
Post by Allen » Mon Sep 14, 2009 5:25 am
Great tip about the chalk Matthew. Will come in handy down the track for all kinds of things I'm sure. I've just got the white chalk, and it's pretty hard to see on spruce, but I've never thought of getting a different color 'cause I've got a half box of white on the shelf. :?
Post by Nick » Mon Sep 14, 2009 6:12 am
Interesting fix, thanks for posting Matthew. Am I right in assuming that the grain orientation of your patch is "in line" because you've let it into the top wood? (allowing any top 'movement' to be equal) Rather than the cross grain cleats that are glued onto the surface on a flat top.
Once again thanks for posting, it's always good/interesting to see work on 'other' types of stringed instruments & I love the work you do with your basses.
matthew
Post by matthew » Mon Sep 14, 2009 6:15 am
your assumption is correct, although the grain is slightly askew to strengthen the area even further. The patch doesn't strictly need to be inlaid but the alternative would be very chunky, and probably stifle the sound.
I don't use cross-grain cleats much, I prefer the grain to be diagonal and the cleats to be feathered away to nothing.
Post by Nick » Mon Sep 14, 2009 6:23 am
Yeah it looks a far more 'complete' fix than cleats to me also. Looks more professional & like somebody has gone to more effort to fix it (which of course you have).
Post by kiwigeo » Mon Sep 14, 2009 7:45 am
Bassmeister!
Joe Sustaire
Post by Joe Sustaire » Mon Sep 14, 2009 10:55 pm
Very cool fix! You know there had to be some mighty anquish felt when that bass hit the floor. Nice to see how you go about doing such a repair!
Thanks,
Joe
Post by Craig » Fri Sep 18, 2009 7:52 am
This is an incredibly good repair Matthew . Very impressive to say the least . Appreciate your documenting it here on the forum for us all to see
Craig Lawrence
