sound hole binding
sound hole binding
We need to get back to the main business here folks so here we go.
I've tried binding a few sound holes but over time I'm noticing some separation from the top. I take some BWB purf and bend it on the hot pipe. Then I cut it to length with a 45 degree at the ends. When the ends meet under the fingerboard I can use them as a wedge to clamp the binding to the soundhole edge. HHG. This is on Ukes.
Thing is, I've notice a few small gaps after a few days.
Is there any way to get a better even clamping pressure. I'm thinking of somehow to use a balloon or a piece of slotted pipe bigger than the hole.
Any thoughts?
Liam
Any thoughts?
Liam
Re: sound hole bindind
There was a post some time back (could be fairly recent since we lost so much data
) that showed a tapered drinking glass used as a wedge to apply clamping pressure.
I've just done one and used SM brown binding tape to pull it tight to the sound hole. After a week it seems fine.
I'm thinking that there is also the possibility of using something like rubber that is fairly flexible and close to the correct diameter, A hole drilled trough the center and a bolt with a washer and nut to compress the rubber, thus forcing it to a larger diameter. Much like the drums on my bobbin sander work to hold the sandpaper sleeves firm.
As you suggest a piece of PVC pipe with a slot cut so it can be squeezed together and lapped inside itself should do the trick just fine Liam. You could then use a bladder inside of that to increase pressure if need be.
G'day Liam,
My method is to inlay the binding into the soundboard before cutting out the soundhole.
Leave the soundboard a little thicker than you require .Route a slot which doesn't quite reach the full thickness of the soundboard and glue the binding in. When dry , thickness the underside of the soundboard to expose the binding channel . Cut out the soundhole and you're done .
Craig Lawrence
Forgot to mention , I bent the Mahogany binding ( 3 mm. ) on my hot pipe prior to installing
Craig Lawrence
I've got nothing......Just look at Craig's. He's the guru.
Craig - what sort of timber is your soundboard made from? It looks spectacular.
Thanks Allen .
Steve , it's Sitka Spruce . A really nice well quartered piece. The whole board is covered in that 'silking '. It's exceptional
I bought the back and sides as Pommele figured African Mahogany and used it also for bindings , purflings and rosette etc.
Craig Lawrence
Re: sound hole binding
Nice method Craig, I may have to have a go at it as the channel would definitely hold everything tight whilst the glue drys! I've just done a tapered end with mine & a little 'extra' help from binding tape if I see any small gaps or lack of glue squeeze out.
Craig that's an idiot proof method for sure. thanks mate.
Craig's method seems like a great idea.
But if you have already cut out the soundhole, here is a video tute from Nigel Forster that I found helpful. http://www.youtube.com/watch?v=9f_t-wGo ... re=related
If you want to clamp it in the hole look for something conical to jam in there and apply expanding pressure. My kids had some plastic cones that they used for soccer training (like the ones at roadworks, but a bit smaller). That was just the right diameter to jam in, and titebond doesn't stick to the plastic.
Thanks for that link Mark . Yes I'm sure that method works well too. Might also be handy should you want to make your soundhole smaller at a later date (lower the resonance )
Craig Lawrence
- Stephen Kinnaird
Craig, I'm with the other Steve--wow, that's a beautiful piece of Sitka.
And your s/h binding trick is quite clever.
(Wouldn't have thought anything else of ya.)
G'day Steve . ,,,It's been a while . Yep I sure got lucky with the Spruce. I've struck 'silking' with Sitka before , but never to this degree . I'm told it's got a lot to do with it being cut perfectly on the quarter , but I gotta feeling there's a bit more to it than that.
Onya Steve
Onya Steve
Craig Lawrence
- Stephen Kinnaird
Indeed there IS! Has to be cut on a new moon (in the winter), has to be from a tree on the north face of the slope, must be from 200' elevation or more, must be from a mixed species forest. (And if a guy named Horst cut it, that doesn't hurt.)Craig wrote:G'day Steve . ,,,It's been a while . Yep I sure got lucky with the Spruce. I've struck 'silking' with Sitka before , but never to this degree . I'm told it's got a lot to do with it being cut perfectly on the quarter , but I gotta feeling there's a bit more to it than that.
I've only seen two tops that came close to the one you picture, but still yours spanks 'em.
Be sure and double the price on that guitar!
Strange you should mention that ...................Stephen Kinnaird wrote: (And if a guy named Horst cut it, that doesn't hurt.)
Craig Lawrence
Users browsing this forum: Google and 76 guests
