Now I'm going to have to find out what a Toneright is....
_________________
Dave White wrote:Kim wrote:
I don't believe there is any 'benefit' in having any amount of movement what so ever in the UTB and in fact will happily go on record as stating that any movement at the upper transfer brace (UTB) will only sink string energy into the upper bout and neck block thus reducing the effectiveness of the lower bout which, in my opinion is the area of the instrument that is the very essence of a responsive guitar.![]()
Kim,
Big statement there !! Some of us "flat earthers" believe that the upper bout is a very important, if subtle, part of the instruments sound potential - I think that Rick Turner is one too.
It's interesting to read of builders Damascene Conversions on this issue - here's one from Tim McKnight.
I'll pray for you my son![]()
Kim wrote:
Also I should define my earlier statement re; any movement at the UTB being a negative toward accomplishing a responsive guitar.
Should a builder have already countered the rotational force of string tension via buttress bracing back to the waist etc, then i concede that the upper bout certainly can be explored as a way of increasing the effective sound production area of the top. Failing that, it is my opinion that any movement or flex of the top at the UTB will at best 'reduce' the responsiveness of the guitar, and at worst indicate a lack of structural integrity.
Allen,Allen wrote:
Now I'm going to have to find out what a Toneright is.... Confused
Kim wrote:
The people at tonerite will sell you one of their highly researched scientific implements for around $150usd plus shipping. If you find that difficult to come up with just after the xmas break and all I will glady wrap a $6 aquarium pump in some inner tube for you and ship postage free for a measly $50...wadaya say huh Cool
Dave White wrote:
I'm in Hog Heaven at the moment as I understand that the Laws of Physics as we know them are currently broken, as the equations break down when you get to what's happening at the centre of Black Holes - they divide by zero and become infinity which isn't allowed apparently.
Lillian wrote:
Ooo I want one!
Kim,Kim wrote:
Sounds like spaghettification boglenese to me Dave Wink
Dave next time you have a rimset made up and lined and with any CF bracing in place, take it out an stand it on the tailblock end and sit on it.Dave White wrote:
Kim,
I may have got this wrong but I think that the rim set is an incredibly strong structure and making braces that connect the top of the neck block into the rimset just below the waist and into the line of the rimset around the lower bout (whether they are CF or spruce or whatever) strikes me as a better way of dealing with the forces from the neck than trying to glue the fingerboard to the top and bracing the feck out of the upper bout. Taking them from the top of the neck block to the back at the waist and I'm not sure where the forces are going. I also use a pair of CF braces at the bottom of the neck block that are parrallel to the top ones, but I know that Rick thinks that these aren't as effective as they are under tension rather than compression and he uses the CF capped centre method to counter the force trying to flatten the back.
Overall stiffening the rimset and using it to dissapate the string tension forces seems to be a good plan to me
By the way - perversely I also use A frame brces on the top inlet into the neck block and a soundhole patch like Fylde, Lowden etc.
Does it break or bend even just a little?
It is missing the most important structural elements, the top and back.
You cannot dissapate string force into other areas, It still has to find it's way back to the bridge
