Kerfed Linings for small instruments
Post by Allen » Mon Jan 03, 2011 6:00 pm
Been awhile since I've started a post as it's been really hectic around the place for quite some time, but a little down time over Xmas and getting some projects well underway allowed me to pull out the camera and take some shots.
I've never liked the size of the kerfed linings that are sized for guitars going into something as small as a ukulele, so have usually made solid linings for my own, or made custom sized kerfed ones. But after a good buy on some ods and sods of various linings on the OLF Swap meet many months ago I decided that many of them weren't good enough for guitars, but just right for ukuleles I picked out a small amount of the stash and after thinking about what I wanted to accomplish and trying a couple different machining operations I settled on using my Stew Mac fret slotting blade to slice these guitar linings approximately in half thus doubling my lining inventory and giving me something much more appropriately sized for a uke.
Reverse kerf linings, One half to be used as intended, the other can be used with either the web inside, next to the side, or out and in the reverse scenario as above.
While the machine was set up I cut up a bunch to get me through the next couple of months.
ernie
Re: Kerfed Linings for small instruments
Post by ernie » Tue Jan 04, 2011 12:16 am
:| Nice work allen. I use both mehods either straight linings or kerfed for ukes. The only problem with kerfed linings is using a kerf that leaves about 1/2mm flat to bend around the tight curves , which can breakout either using solid or kerf linings. I also use 4 species available here in the midwest western/ tenn red cedar, basswood ,or willow. I have also used small spanish style tentellones single blocks using hide glue to glue the liningsto the top rib, and a solid liner for the back. hope this helps ernie
Post by Allen » Tue Jan 04, 2011 6:48 am
Used all those methods as well Ernie. I'm doing a cutaway tenor right now and the curves around the horn are very tight indeed and some of the pieces need to be individually shaped and glued in as tentellones in that area.
Post by rocket » Tue Jan 04, 2011 8:34 am
I kerf both sides for those tight bends.
Cheers,,, Rod
IMG_0894 (Custom).JPG (58.8 KiB) Viewed 5772 times
Puff
Post by Puff » Tue Jan 04, 2011 8:52 am
Yep - Essentially homebuilt Squiglewood. Great stuff :D
Post by Allen » Tue Jan 04, 2011 7:38 pm
Just showing off Rod. :D
And no, I've not tried that one yet, but will the next time around. Though I'm not sure it will be enough, as on a tenor uke, those bends are REALLY tight.
Thanks for the tip.
Users browsing this forum: Google and 170 guests
