I have made my first major mistake (cant believe I got this far) and I was wondering if you guys could give me some advice and where to go from here.
I drilled the tuner holes for my slotted headstock this morning. I knew the day was going bad as I woke up with a stinking headache. Anyhow I got myself right before I went into the shed. All went well on the first side. The holes are a bit tight so I decided, stupidly to drill them out a bit by hand. I still had the tape on the bit to make the depth, unfortunately what I didn't realise is that I had set the depth for the top of the doweling jig that I am using. Anyway long story short I drilled right though on the center hole
![Embarassed :oops:](./images/smilies/icon_redface.gif)
I am thinking that maybe I can buy some dowel to plug the hole before I drill the holes on the other side (I have already drilled the top hole, see pic). Any other suggestions?
Thanks a lot guys I appreciate it.
![Image](http://i325.photobucket.com/albums/k366/bambam99_photo/IMG_20110705_114253.jpg)
