i'm having an issue with my recently purchased ryobi 400w bandsaw. When i'm cutting the blade bend and doesn't cut straight. when i've got the guide up it pushs right out to one side and gets jammed
thanks you.
1. Is this a 14" bandsaw or something smaller? I assume its one of these: http://www.ryobi.com.au/Products/PowerT ... 4023L.aspx Probably a bit underpowered and small for alot of luthiery work. I wouldnt go smaller than a 14".snakey wrote:Hello all
i'm having an issue with my recently purchased ryobi 400w bandsaw. When i'm cutting the blade bend and doesn't cut straight. when i've got the guide up it pushs right out to one side and gets jammed. i've ajusted it right out to it's end and i've adjusted all the guides and track. i've broken 2 blades already.
thanks you.
Cant really give an accurate assessment without seeing the machine Snakey but IMHO given the size and power of your machine it may just not be up to handling 80mm thick maple. If youre using the blades that came with the machine then they may be the issue....the blades that came with my Carbatec 14" were pretty average.snakey wrote:Yeah its that piece. um the blade is brade new, i'm using about 80mm thick maple and its got block guides with a thrust bearing behind.
$34!!! Tell 'em theyre dreamin'!snakey wrote:ah sweet so where would you recommend i get a blade from? bunnings wants 34 buck for the same blade i have now and thats all they have
Check the Ubeaut woodworking forums and ebay. Theyre's usually a few 14" bandsaws going for a decent price. Ive got a Carbatec 14" bandie that's ok bit I'm upgrading to a 17" when I get the chance.snakey wrote:hmm ok sweet i'll check it out. um i've tried 60 mm with the guide right above and it went ok. but not great. i think i'm stuck with this crap till i can sell some ukes and buy a good one
Good point on the wood jamming against the fence. Looks like you discovered blade drift the same way I did!Alastair wrote:All the above![]()
However, just a quick question: Are you using the rip fence to do your resawing? If so, and unless the blade is both perfect and tracking straight, any blade drift can act to squeeze the timber up against the fence, and then cause the blade to "bulge" away from the fence until it jams/breaks.
Try cutting freehand, (without the fence) following a line, or else make up a "single point" fence on which the timber can pivot to follow the cut, and allow for blade drift.
Does your machine have lower blade guides as well as upper guides?snakey wrote:Thats exactly whats happening. i dont think the blade is straight. might need to make up a single point fence thank
I wouldnt be trying resaws with this machine......resawing is getting close to the limits of even alot of 14" machines.snakey wrote:well i've got a new blade on it the replacement 1 get get when i take it back for warrenty and its cutting heaps better but resaws are a bit much for it.. i'll have to take it really slow which is going to be painful but i don't want to break another blade.
Im planning to get a bands saw so have been researching what I need.snakey wrote:Another quick question,Whats the difference between a resaw blade and a normal blade..
