Angle SIdes - 15" Back on Weissendborn
Kim Strode
Post by Kim Strode » Sat Jul 28, 2012 3:59 pm
I am currently building a Weissenborn. I have the back almost finished, which is curved to a 15" radius, braced and almost ready to glue to the sides. I now need to angle the sides to match the 15' radius of the back....any suggestions for an effective technique. I don't believe I can use a radius dish with sandpaper as the back is only curved around the bottom and sides and not at the neck extension. Suggestions welcome.
Kim Strode
Daylesford, Australia
Re: Angle SIdes - 15" Back on Weissendborn
Post by Bob Connor » Sat Jul 28, 2012 5:19 pm
I'm not sure what you do there Kim.
I build mine with a flat back mainly because I couldn't figure out a way to radius the sides with the dishes that I have. So a flat back is much simpler. I do a flat top as well.
If it were me I'd chisel the braces off make it a flat back and save yourself a lot of head scratching :lol: It may just be the quicker and simpler way to go.
Dave White
Post by Dave White » Sat Jul 28, 2012 6:02 pm
Kim,
Use the old chalk technique. Cut the inlets for the brace ends in the linings then mark around the edge of the back with chalk to see where it touches the linings. Keep removing where there are chalk marks on the linings and deepening the brace inlets if necessary. Repeat until it fits.
Dave White
Post by Kamusur » Sun Jul 29, 2012 8:22 am
Hope i have understood the question you asked Kim .....are you trying to change the bottom plate contour from 15 feet (not inches) dished radius across the neck joins body area (in side profile/side elevation that is) to flat as the sides diminish to the headstock area ,or are you after some sort of radius in the profile either cylindrical or spherical continuation but in the different plane?
Kim Strode
Post by Kim Strode » Sun Jul 29, 2012 9:05 am
Hi Steve, I'm looking for a method of sanding or planing the sides where they join to the radius back, to ensure there is a good side-to-back join.
Kim Strode
Post by jeffhigh » Sun Jul 29, 2012 9:51 am
I built mine with flat backs across but in your situation I would probably use a 12 thick 100mm wide sanding board, deformed to approximately 15' radius by a central screw into a thicker beam and packing at the ends.
Post by Trevor Gore » Sun Jul 29, 2012 10:34 am
A dome is a dome is dome. Which is the great thing about domes.
So as I see it (I hope I'm understanding this) you have two options:
1) Dome the rims over their whole length (butt to headstock) with the high point of the dome towards the top of the upper bout. This will, of course, narrow the depth of the rim quite a bit at the butt and the head. To get the profile, sit your 15 foot dish on the rims, one edge of the dish flush with the butt, with a packer (probably about 10-15mm thick) between the rims and the dish at the base of the neck. Then use the mechanical-pencil-through-a-scrap-of-wood-trick (see pics) to scribe a line around the rims. Leave the packer where it is, shift the dish to the neck end and repeat. Block plane close to the line and finish up with the dish with sandpaper glued to it. This should blend everything (because a dome is a dome is a dome) and the dish should "fit" everywhere (and hopefully your linings are deep enough)
2) Do as above for the "body" of the guitar, but at the neck, come off the dome as a straight line tangent and keep the neck flat. Sand the body using the dish with sandpaper glued to it and sand the neck with a flat sanding block.
Of course, the real recommendation is to plan a head a bit, choose your back panel profile, mark/plane/sand your rims to suit, then glue your linings in and trim up. And only then notch for the back braces.
Here's the mechanical-pencil-through-a-scrap-of-wood-trick:
In this pic, the dish is on the top and I'm scribing around the sides, keeping the bit of wood in contact with the dish all the way around. In your case, the scrap of wood will need to be the other way up (pencil at the far side from the dish), because it has to bridge the gap between packer and the rims.
Post by Nick » Sun Jul 29, 2012 12:22 pm
Paddle stick sander with the appropriate packing under the handle of the paddle to set the sanding face at the correct angle? The angle would change slightly of course as the handle bridges the various different length of rest points(the opposite side) but it would get it close that you could then sit the sides in your dish with the neck section hanging over as you've done with your back, & spin it back and forth on an axis (I think John Hall refers to it as "steering the bus" :shock: ) to finish it off. Maybe put some thin cardboard over the neck section so that you dont undercut the neck with the dish?
Kim Strode
Post by Kim Strode » Sun Jul 29, 2012 6:25 pm
Thank you all for your suggestions and ideas...I'm sure a combination of these ideas will work well.
Kim Strode
