bridge deflection gizmo
Trying to avoid math as much as possible I rigged this up tonight to check the deflection on my OLF challenge build ..works pretty good, I drew up the scale on my cad program and is held in place by a telescoping magnetic pick up tool and attached to a cheap harbor freight dial indicator base, the pointer is a alligator clip with a piece of music wire soldered in...right at 2 degrees deflection per Trevor's guidelines!!!
- 2012 11 15_0368.JPG (141.29 KiB) Viewed 5492 times
- 2012 11 15_0369.JPG (177.86 KiB) Viewed 5492 times
- 2012 11 15_0370.JPG (175.78 KiB) Viewed 5492 times
- 2012 11 15_0371.JPG (164.33 KiB) Viewed 5492 times
Re: bridge deflection gizmo
Neat!
- woodrat
I'm impressed also!....well done Weslewis!...great idea!...and thanks for sharing!
