Pocket Froe
Pocket Froe
Post by charangohabsburg » Sat May 04, 2013 2:55 am
A pocket froe. Well, it depends on the size of one's pocket, of course. I also could call it "desktop froe", but this would not be very descriptive as just about any desktop is big enough in order you can put a froe on it...
So, this is my brand new pocket froe, just about the size needed for splitting bracewood.:
The following photos depict some stages of the manufacturing process.
Maybe you remember this one - my tool steel supply I got about two years ago:
This time I picked an old, blunt and dirty file out of the tool steel pile:
Getting held agains my grinder the file lost its teeth, and with some coarse sharpening stones and a bit of patience I got the blade reasonable even, flat and sharp:
The I cut off a piece of 20x4mm flat iron and made a square, according to the file tang conical hole in it:
Image .
Image .
Image .
... and tapped this lever on to the tang:
Image .
Image .
Image .
Then I brazed the two pieces to not come lose when in use, and mounted the original handle after having filled the worn out hole with a dowel, and after pre-drilling a new hole for the tang:
Normally, pushing the lever with the thumb is enough to wiggle the pocket froe though the readily splitting wood. Like this:
That's all. Thanks for looking.
EricDownunder
Re: Pocket Froe
Post by EricDownunder » Sat May 04, 2013 6:57 am
Like that, it's always good to recycle old files 8) .
Keep Smiling,
Eric Smith
Re: Pocket Froe
Post by rocket » Sat May 04, 2013 9:37 am
Nice work Markus, very clever.
colburge
Re: Pocket Froe
Post by colburge » Sat May 04, 2013 5:36 pm
Thanks for the tip, I might stock up on old files when I go to the local market, there is a guy there every weekend with a truck full of old tools.
Col
Tod Gilding
Re: Pocket Froe
Post by Tod Gilding » Sat May 04, 2013 6:57 pm
I think that I already have one of these on my Swiss Army Knife. :)
Re: Pocket Froe
Post by Kamusur » Sat May 04, 2013 8:30 pm
You come through with the goods again Markus, is it Swiss Spruce you are splitting?
curly
Re: Pocket Froe
Post by curly » Sat May 04, 2013 9:39 pm
I like it , a very neat job there .
My version is a heavy blade japanese bone cleaver , mighty effective . Not so elegant .
The froe doesn't lie , soon weeds out timber with run off . A handy trick i've been shown is to always spilt the billet into halves , getting progressively smaller , it saves getting splits that jump across the fibres .
By the way if anyones interested there's a froe on ebay right now , I think they called it a large shingle splitters axe , a froe it is .
Pete
Re: Pocket Froe
Post by charangohabsburg » Sat May 04, 2013 11:30 pm
Thanks everybody for your comments!
@ Eric and Col: it is a good idea (at least for me) to always have some tool steel around, just in case of the need of some kind of new, maybe special blade. For me, old files and sawblades are the best and easiest resources, I am not thinking much in recycling when using them. Although, of course recycling is always a good thing. 8)
Tod Gilding wrote:I think that I already have one of these on my Swiss Army Knife. :)
Of course, there is no tool you can not find on the Swiss Army Knife. It even sports a thickness sander (if you have the patience and skills :twisted: :mrgreen: ).
Kamusur wrote:You come through with the goods again Markus, is it Swiss Spruce you are splitting?
Thank you Steve, and no, it is not spruce (but almost). What you see comes from this stem, which is Silver Fir (Abies alba) from the woods in the neighbourhood (a 500 meter walk away):
Silver Fir seems to have about the same stiffness to weight ratio as Spruce and, unlike the latter one has (almost) no resin pockets at all which makes it a highly appreciated construction lumber here around.
curly wrote:I like it , a very neat job there .
Thank you Pete!
curly wrote:My version is a heavy blade japanese bone cleaver , mighty effective . Not so elegant .
Before making this "pocket froe" I also thought of some heavy knife like your bone cleaver, but then I just started to like the control this lever gives you when splitting the wood. I have a big and heavy froe (34 cm blade, 2 kg) which I use to split log halves into smaller pieces (for entire logs I prefer wedges). Using that froe I came to the conclusion that I would not like it very much handling that kind of weight on my "desktop" (= bench top, of course).
curly wrote:The froe doesn't lie , soon weeds out timber with run off .
Too true!
It is really amazing what one can find within one tree stem.
Here, still the Silver Fir from above, I got a slight but still rather acceptable twist:
One meter further down the stem things got really wild, from just about the same twist as above in one half, to this:
Click on the picture for more photos of the same piece at slightly different angles of view and lighting
:shock:
Splitting such interlaced/wavy grained wood with a froe is close to impossible and it is better to use wedges, or a saw if one wants to make something else than firewood.
Sometimes there are very notable differences even within the same length and within the same quarter!
curly wrote:A handy trick i've been shown is to always spilt the billet into halves , getting progressively smaller , it saves getting splits that jump across the fibres .
Yeah, shingles... Have a look at this man, how he produces some of the nicest Western Red Ceder guitar tops - for roofing his house! :shock: :dru
Picture found here.
Re: Pocket Froe
Post by Kamusur » Mon May 06, 2013 9:54 pm
Markus, 500 metres, that is so cruel I mean cool. The felled logs looks pretty damned straight and not much in the way of any significant limbs..reminds me a little of Port Orford Cedar (Cypress Pine) is there maybe a top or two in that trunk?
Re: Pocket Froe
Post by charangohabsburg » Mon May 06, 2013 11:39 pm
Yes Steve, there were "a top or two" in that trunk! :lol:
But as I have pointed out before, not all lengths were so nice, I mean that sometimes the grain would only be straight in one direction or had a severe twist which would have resulted in a twist in the range of 1:15 runout or worse. I had ended up resawing only three lengths, the rest is rotting away now and getting eaten up by the bugs - they especially love the sapwood ;). Last week I was splitting the 8 quarters of some other two lengths to get some bracewood, but two of the 8 quarters are only good for firewood (see the picture above with the interwoven grain).
Kev3
Re: Pocket Froe
Post by Kev3 » Tue May 07, 2013 6:12 am
Don't know about the twist being only good for firewood Markus. So artfully imaged I think there's a market for poster sized photos. I'd happily have that one the wall :D
Kevin
Re: Pocket Froe
Post by charangohabsburg » Tue May 07, 2013 7:19 am
Hi Kevin. Yes, of course there is always a market for great photographs but I'm afraid (no, I'm sure) that the ones you see above don't qualify. However, if you like them feel free to download here their full resolution versions and print them, or get them reproduced at your preferred size ;).
Maybe I should sell the wood itself at an exorbitant price, saying it was something special. I reckon this would make one nice blister figured and dull sounding (or alternatively: collapsing) guitar top - or one could hang the wood as piece of modern art on the wall. :lol:
Re: Pocket Froe
Post by DarwinStrings » Tue May 07, 2013 12:19 pm
If you really want to mount it on the wall and call it "modern art" then you will need a critical discourse to got with it or it will just be a piece of wood on the wall, if you need help with that I would be glad to help.
Kev3
Re: Pocket Froe
Post by Kev3 » Tue May 07, 2013 2:55 pm
Deliberately choosing a top that will collapse ? - Now that is starting to sound like so many other examples in modern design and manufacture that have components with built in obsolescence :twisted:
I'd stick to the modern art idea (accompanied by a critical discourse from Jim of course) :lol:
Kevin
Re: Pocket Froe
Post by charangohabsburg » Tue May 07, 2013 11:30 pm
Thank you Jim and Kevin. It seems we have now at least two excellent viable marketing options for firewood! :lol:
Users browsing this forum: No registered users and 202 guests
