Starting Front Head Stock Carving
- chris paulick
Re: Starting Front Head Stock Carving
OK did some shaping of top Bud and elsewhere. Almost done ...I think.
- head1almost done.jpg (159.96 KiB) Viewed 11046 times
Chris
- matthew
very, very cool. Total class.
Wow! Hats off!
Wouldn't even know where to start, or even have the patience to finish such a thing.
- chris paulick
OK here's the latest update. I worked on deepening and evening out of the stipple pattern and defining the shaped and veining work on leaves. Some undercutting to define shapes and also the stipple deepening also helped by producing more shadow. Rounded/softened the hard edges with a few grits of micro mesh which also polished high areas for light reflection and gives carving a more organic look/feel. Trying to decide whether or not to do something with the 1" space between the slots and under the point. If decide not to then it's onto the finish. I'll think about it over a cold brew...
Chris
I think I want a Chris Paulick guitar and am not sure if I even care about how it sounds.
- chris paulick
- matthew
Superb Chris. If it was mine I think I would do something in that space. A leitmotif ... leafmotif ... whatever.
- chris paulick
Calling it finished and put an oil finish on it.
Probably better to stop while I'm ahead...
Thanks for watching!
Hope it was worth your time...
Chris
No problem Chris, just charge your customer for the time we spent watching your amazing birth-of-a-headstock-carving thread and it'll be fine!chris paulick wrote:Thanks for watching!
Hope it was worth your time...![]()
Thanks again for your time for showing and explaining the process!
