HHG
PHANTOM
HHG
Post by PHANTOM » Mon Sep 02, 2013 8:28 pm
This is probably a dumb question but I am building my latest two instruments using hot hide glue if I want to thicken it up a bit can I just add less water? Thanks in advance for any help and sorry if this is a stupid question but I don't want to weaken the glue in any way.
Carpe Diem
auscab
Re: HHG
Post by auscab » Mon Sep 02, 2013 9:04 pm
Yes, but you may want to consider doing a time trail on how long it will take you to get the piece clamped into position and consider heating the parts to be glued or the room, or both.
Going for a thicker glue mix can go wrong by the glue chilling and not getting most of it out of the joint in time. I buggered up my first Ebony fret board doing this , and have been caught out plenty of times on other woodworking jobs .
The main cause of a weak joint using HHG is leaving to much glue between the two pieces. I think it's pretty amazing how thin it can be and how well it holds.
PHANTOM
Re: HHG
Post by PHANTOM » Mon Sep 02, 2013 9:12 pm
Thanks for that. I just checked and it is holding well I think its because im use to using titebond it just seemed like there was no glue on the joint compared to titebond,
Carpe Diem
Re: HHG
Post by Allen » Tue Sep 03, 2013 6:01 am
You can vary the viscosity of HHG quite easily by adding water, or leaving the container open while it's heating and evaporating some of it off.
