A better way?
A better way?
Post by DarwinStrings » Fri Oct 04, 2013 12:44 pm
Last night I scribed a bridge to a top and then scraped out the top finish to glue the bridge. Every time I do this I wonder if there is a better way. Maybe I am just a bit slow at it but it does take me quite some time cause I have to be so careful not to slip and then have to repair the finish. This time while I was scraping I considered masking off the area and using paint stripper to soften the finish before scraping to speed things up (might be showing my desperation there :) ). I don't want to try that on a guitar in case it stuffs the glue joint so I may spray up some test panels and try it on that first but before I go to the trouble, has anyone ever come up with a faster method with suitable results?
Re: A better way?
Post by kiwigeo » Fri Oct 04, 2013 12:58 pm
I think youll find paint stripper will leave a goey gunge which youll end up having to scrape off to end up with a clean gluing surface.
I mask off all except the out periphery of the bridge area..that way I just have to do a bit of scraping..doesnt take me more than half an hour to get the job done. I wear a pair of magnifying binocular glasses and make sure Ive got both hands guiding the scalpelt/violin knife when I get close to the bridge line.
Re: A better way?
Post by DarwinStrings » Fri Oct 04, 2013 1:11 pm
1/2 an hour beats me Martin, I am about three times that. I suppose masking off would make me less scared and speed it up a bit.
Re: A better way?
Post by DarwinStrings » Fri Oct 04, 2013 1:17 pm
Oh and you use a violin knife, the one with a handle that looks like a skew chisel? That may be better as I just use a broken stanley knife blade. It wrecks my fingers too, can't play guitar after I scraped the finish.
GregL
Re: A better way?
Post by GregL » Fri Oct 04, 2013 1:23 pm
Hi Jim,
I think Kathy Matsushita uses paint stripper when removing finish for the bridge. Maybe you could check her website?
Thanks,
GregL.
Re: A better way?
Post by DarwinStrings » Fri Oct 04, 2013 1:50 pm
Cheers Greg, I found it on her site. Kathy refers to the stripper she uses as "orange safe" so I checked that and found there is citris strippers available, sounds like it will save me a not so fun job.
auscab
Re: A better way?
Post by auscab » Fri Oct 04, 2013 2:25 pm
Hi Jim ,
Do you glue down your bridges with HHG ? I'm thinking if it would be possible to scribe your bridge position before any finish is put down ,then brush coat within the scribe line with thick HHG, let it dry , finish the top.
Then put bridge back on and re scribe the line to just cut through the finish , after that either scrape through finish to the glue and dissolve the glue back with warm water or warm up the glue with a hair dryer and see if it and the finish moves . I suppose it could be done with other water soluble glues as well
To me , with scraping the finish under the bridge position I have always thought of the danger of damaging finish out side the line and also of creating a less than perfect joining surface, if I was to scrape at any of the sanded top timber.
Re: A better way?
Post by DarwinStrings » Fri Oct 04, 2013 2:52 pm
G'day and thanks Rob, I use yellow glue for the bridge and am happy to stick with that. I don't have any trouble with scraping the joint well, once I get through the finish, it is just the getting through the finish that I find time consuming and wearing on my fingers. Still your ideas sound sound enough.
Re: A better way?
Post by Allen » Fri Oct 04, 2013 5:28 pm
Some use a laminate trimmer with cutter just scoring through the lacquer and cleaning it up that way. I tried it once, but my bum was puckered up too tight for me to continue on with that method.
Others I've heard heat up a knife and use it to scrape up the finish. Not tried it, but I think it was Chuck Moore among others that uses this method.
Me, I've masked off the surface, and then sprayed and buffed. Then pulled tape off. Now I just finish the whole instrument and scrape it back. I mask the entire outside perimiter of the bridge area with tape to give me a bit of confidence in hooking in with a scraper. Takes me about 10 and no more than 15 minutes on my rather complicated footprint on my bridges.
Re: A better way?
Post by kiwigeo » Fri Oct 04, 2013 6:43 pm
Allen wrote: I tried it once, but my bum was puckered up too tight for me to continue on with that method.
:lmao :lmao :lmao :lmao :lmao :lmao :lmao :lmao :lmao
:bum
Re: A better way?
Post by kiwigeo » Fri Oct 04, 2013 6:45 pm
DarwinStrings wrote:Oh and you use a violin knife, the one with a handle that looks like a skew chisel? That may be better as I just use a broken stanley knife blade. It wrecks my fingers too, can't play guitar after I scraped the finish.
That's the one.....Ive got a set of the things and I keep them razor sharp. Theyre good for "hogging out" finish and when I get close to the bridge perimeter I sometimes switch to a scalpel with a stiff blade.
Re: A better way?
Post by Trevor Gore » Fri Oct 04, 2013 7:40 pm
Scribe around, really sharp dog-legged chisel used across the grain, ~15 minutes all up. (Figs 20-23 to 20-25).
vandenboom
Re: A better way?
Post by vandenboom » Fri Oct 04, 2013 9:38 pm
I use the riskier technique Allen refers to using a dremel mounted in the small dremel base, then finish off with stanley knife blade. I do the same in the head block area before gluing fingerboard extension down. Depth testing obviously crucial and dremel has a tendency to walk as the bit is barely touching the surface - so, yeah, all a bit risky but no disasters yet and pretty quick. Frank
Re: A better way?
Post by DarwinStrings » Fri Oct 04, 2013 10:41 pm
Thanks all, that made me chuckle too Allen. I should open that white book of yours more often Trevor. I think I am probably just being too ginger with it and sounds like I need to man up get rid of the stanley blade and scrape a little harder or yep buy one of those dogs leg jobs. I had read about that method Frank, thought I might go too slow and burn the thing.
Re: A better way?
Post by ozziebluesman » Sat Oct 05, 2013 6:47 am
Can't add much Jim I mask off the area under the bridge footrpint mark with a pencil around the outline then use a violin makers knife in a home made handle (one of my first ever projects) and scribe about 2 mm inside the pencil line. Peel away excess and scrape and sand away. I use a French Polish finish and HHG on the bridge glue up.
Re: A better way?
Post by Craig » Sat Oct 05, 2013 7:11 am
It takes me too long as well Jim . Have a try at turning the sharp edge on a smooth bit of hardened steel creating a hook on whatever your using to scrape off the finish.
Don't put masking tape on a recently French polished finish !! or you'll end up very pissed off ? :D
Craig Lawrence
Re: A better way?
Post by DarwinStrings » Sat Oct 05, 2013 12:08 pm
Cheers Alan, Craig. Comforting to know I may not be the slowest kid on the block Craig. Time to improve/change the method so I am looking forward to that bit on the next guitar now.
ozwood
Re: A better way?
Post by ozwood » Mon Oct 07, 2013 3:05 pm
Hi Gents,
Maybe I am missing something or about embarrass my self , But I just put a layer of tape down accross where the bridge is going to sit, position the bridge , score around it with a sharp exacto knife , remove the waste masking tape , spray , level sand and polish to my hearts content and then score around the edge of the tape,remove it and glue my bridge on,........... never a problem, and I know I'm not the only one who does it that way, if there is an obvious down side to doing it , it's not obvious to me !
Just my two bobs worths.
Paul .
Re: A better way?
Post by Allen » Mon Oct 07, 2013 5:38 pm
Nope..........That'll never work............. :lol:
ozwood
Re: A better way?
Post by ozwood » Mon Oct 07, 2013 5:54 pm
Too simple you thinks Allen, not in keeping with complex and sacred traditions of Lutherie........aww shit :( :( :( :( :( , I'm not gonna be cast out am I.... :cry: :cry: :cry: .
Paul .
Re: A better way?
Post by Allen » Mon Oct 07, 2013 6:01 pm
One small step from being banned! :lol:
Re: A better way?
Post by DarwinStrings » Mon Oct 07, 2013 8:43 pm
I have to agree, far too easy Paul, keep your ideas to yourself next time.
Someone ban him so I can use it without him knowing please.
Re: A better way?
Post by Craig » Mon Oct 07, 2013 8:55 pm
Sorry Paul ,,,,,,,,,,You're out
Craig Lawrence
Re: A better way?
Post by charangohabsburg » Tue Oct 08, 2013 3:49 am
Wow, the last secret in luthierie has surfaced. :shock:
From now on luthiers will be just normal people like plumbers, professors and pedestrians are. :(
lauburu
Re: A better way?
Post by lauburu » Tue Oct 08, 2013 5:50 am
+1 for Ozwood
Guess I'll have to ban myself as well
Miguel
Users browsing this forum: No registered users and 59 guests
