help identifying wood.
It is fine grained and approx density of heavy spruce. Thanks in advance.
Craig.
Re: help identifying wood.
I have some bunya pine and hoop pine that looks similar to that. Could be one of those.
Yeah ditto ,
Hoop or kauri are most likely .
Pete
Pete
Don't know my Aussie woods very well but this example has similarities to NZ kauri.
Miguel
Miguel
Thanks Mat, Curly and Lauburu. It's looking like the Kauri is the best match. I don't have any with vertical grain so will probably just split it and use it for bracing. Are there any know issues with stability etc?
Craig.
Craig.
Kauri is very stable once it's dry. Most of NZ's early houses were made of made of kauri. Not sure if the stiffness to weight ratio would make it ideal for bracing. Only one way to find out.
Miguel
Miguel
Thanks Miguel. I will start with back braces until I can do some comparisons with spruce that I have.
Craig.
Craig.
Users browsing this forum: No registered users and 165 guests
