Fretted to Fretless Conversion
mickeyj4j
Re: Fretted to Fretless Conversion
Post by mickeyj4j » Mon Dec 14, 2015 7:19 am
kiwigeo wrote:Carbatec normally stock it. I got mine here but they wont post out the accelerator because it's in an aerosol. They also have the spare tips and micropipettes. http://www.thewoodsmith.com.au/thewoods ... tuff01.htm
seeaxe wrote:Also stocked in carbatec nz, they are on Harris road east tamaki. They have a good website.
Thanks guys is the accelerator beneficial and necessary.
Post by kiwigeo » Mon Dec 14, 2015 7:48 am
You can generally do without it. Depends what sort of work you're doing. Eg the other day I was gluing up pieces of burl into a rosette. The accelerator allowed me to speed up the job. One thing to watch is that you don't spray on too much accelerator as it will result in a hard white crust.
Post by jeffhigh » Mon Dec 14, 2015 9:56 am
No need for accelerator on this job, leave it for an hour and you are good to start trimming then sanding.
slowlearner
Post by slowlearner » Mon Dec 14, 2015 1:52 pm
A few people will want to rain cow poo on me... but I've had plenty of success with cheap, supermarket superglue on fretmarkers (and a host of other things too).
I've used tru-oil, wipe on poly or just boiled linseed oil to finish 3 different fretless boards and had great results.
P.s. I'm keen to try a wipe on CA finish at some stage too. Just make sure your work area is well ventilated, otherwise you'll float back out of the shed... :shock:
Pete
Post by jeffhigh » Mon Dec 14, 2015 3:11 pm
slowlearner wrote:A few people will want to rain cow poo on me... but I've had plenty of success with cheap, supermarket superglue on fretmarkers (and a host of other things too).
Yeah same here
lauburu
Post by lauburu » Tue Dec 15, 2015 7:26 am
And also with $2 Shop superglue. The biggest difference I've noted is that the unused $2 Shop stuff is unusable next day. Perhaps more to do with the airtightness of the container than the quality of the contents?
However, I always use the expensive stuff on mission critical components and the cheap stuff on non critical work.
Miguel
Users browsing this forum: No registered users and 142 guests
