Four Flute Router Cutter
Dave M
Post by Dave M » Thu Dec 10, 2015 7:28 am
I recently discovered this cutter. It cuts incredibly smoothly and made me feel much safer removing the overhangs of the top and backs on my just closed box.
It is a half inch spindle so is quite a chunky bit with bearings top and bottom, but given the smooth operation it doesn't feel too frightening.
Re: Four Flute Router Cutter
Post by Mark McLean » Wed Dec 16, 2015 9:59 pm
Where did you get it Dave?
Post by kiwigeo » Wed Dec 16, 2015 10:35 pm
Mark McLean wrote:Where did you get it Dave?
Carbitool may have such a cutter...it's where I get most of my router cutters.
Dave M
Post by Dave M » Thu Dec 17, 2015 4:34 am
Mark I am in the UK so this is probably not too useful for you. For interest from the UK I bought it at Wealdens Tool company. You have to search their site a bit as they keep it hidden away.
It may be that these are not that uncommon but I have only just come across them, and the double bearing cutters also seem a bit hard to find.
Cheers Dave
Jeremy D
Post by Jeremy D » Fri Dec 18, 2015 8:39 am
Jeremy D
Post by Mark McLean » Sun Dec 20, 2015 9:49 am
OK. I think I will get myself one of those. I recently made up something similar by adding a bottom bearing to one that only had a top bearing. But this looks better. And you can never have too many router bits!
scuffle
Post by scuffle » Mon Dec 21, 2015 4:21 pm
I havent managed to get one yet but I know these guys have a great reputation.
http://www.radiantools.com/products/1/3 ... mm_x_50mm/
Andrew Hobson
Post by kiwigeo » Mon Dec 21, 2015 5:42 pm
scuffle wrote:I havent managed to get one yet but I know these guys have a great reputation.
Thanks for the link.
Nice looking cutters but at 47 pounds plus postage on top of that......the Carbitool cutters will work out cheaper for Australian customers.
scuffle
Post by scuffle » Tue Dec 22, 2015 11:20 am
no doubt. Would probably work out three times as expensive!
Also this one is 2 inches long rather than 1 - 1 1/2 inches from Carbitool. You blokes might not need that much but I do when doing solid bodies :)
Andrew Hobson
Post by kiwigeo » Tue Dec 22, 2015 11:26 am
scuffle wrote:no doubt. Would probably work out three times as expensive!
How much are you guys paying for a pint of warm beer these days? :mrgreen:
scuffle
Post by scuffle » Tue Dec 22, 2015 12:04 pm
Sorry mate I dont understand. Do you think I am from the UK?
Andrew Hobson
Post by kiwigeo » Tue Dec 22, 2015 12:10 pm
Sorry got you mixed up with Dave M.
Latrobe Valley...that's VB country isnt it? Ya might as well be drinking warm Pommie beer :mrgreen:
Woodsy23
Post by Woodsy23 » Tue Dec 22, 2015 1:03 pm
I bought a few router bits from MLCS in the USA (when the Aussie Dollar was better), including a 2" long double bearing flush trim bit from their premium "Katana" range. It is only 2 flute but is really good quality. See link
http://www.mlcswoodworking.com/shopsite ... bot_anchor
scuffle
Post by scuffle » Tue Dec 22, 2015 4:57 pm
kiwigeo wrote: Sorry got you mixed up with Dave M.
I could think of worse things to drink :lol:
Andrew Hobson
Post by kiwigeo » Tue Dec 22, 2015 5:32 pm
Like Westend :drink1
slowlearner
Post by slowlearner » Tue Dec 22, 2015 5:49 pm
Dave M wrote:It is a half inch spindle so is quite a chunky bit with bearings top and bottom, but given the smooth operation it doesn't feel too frightening.
Man, I know what you mean about frightening. I HATE my 1 1/2" long trim bit. Sure, it cuts well enough, but it also tears out pretty fast. Scares the heck out of me.
:shock:
Do the extra 2 cutting edges make it smoother?
Pete
Dave M
Post by Dave M » Thu Dec 24, 2015 5:23 am
Pete it does feel smoother but I suppose you could in theory just run a two cutter bit faster to get the same result.
A lot of how it feels must be about how well the bit is balanced and maybe I just got lucky that this one is sharpened to a small tolerance. It is also new of course which helps.
I guess a proper engineer could tell us a lot about optimum speeds, type of cutter etc, which I am not!
Cheers Dave
Post by kiwigeo » Thu Dec 24, 2015 8:27 am
Dave M wrote:Pete it does feel smoother but I suppose you could in theory just run a two cutter bit faster to get the same result.
Cheers Dave
Keeping the cutter sharp helps as well. I give the the backside of the flutes a dress with a diamond card sharpener after each use.
Users browsing this forum: No registered users and 47 guests
