blushing with 3220
scuffle
blushing with 3220
Post by scuffle » Sat Jun 04, 2016 1:42 pm
Hey all,
Just spraying a solid black on a guitar this morning and low and behold...i have encounered blushing for the first time :/
Im was pretty sure it was going to happen because its been raining and its icy cold. As far as I know thats what causes blushing yes?
Anyhoo is there any way of fixing it without sanding it all off? I'm using Miritone 3220 gloss
Andrew Hobson
Re: blushing with 3220
Post by simso » Sat Jun 04, 2016 2:18 pm
Spray a light coat of thinners over the blushed area whilst its still fresh, I use an airbrush, it softens it enough to allow the moisture to escape, having same issues over here in Perth
scuffle
Post by scuffle » Sat Jun 04, 2016 3:34 pm
Cheers mate! That worked a treat :)
Andrew Hobson
Post by Allen » Sun Jun 05, 2016 6:26 am
Always add extra slow solvent to the mix. No matter what the temp or humidity.
5% does the trick. Never more than 10%
Your finishes will come out worlds better because the lacquer will flow better, and it stops blushing by keeping the surface film from skinning over so quick.
scuffle
Post by scuffle » Sun Jun 05, 2016 10:44 am
Cheers Allen :) Do Mirotone make a specific slow solvent?
Andrew Hobson
Post by Allen » Mon Jun 06, 2016 6:55 am
Yes. It's bloody expensive, but you only need a little so it goes a long way.
Post by Bob Connor » Mon Jun 06, 2016 7:41 am
Mirosol 1218 ultra-slow thinner is what I use.
Users browsing this forum: No registered users and 56 guests
