Buffing
Buffing
Post by simso » Fri Jan 06, 2017 4:33 pm
http://www.mirwa.com.au/HTS_Buff.html
This one may be different for everyone here, but this is my process
Re: Buffing
Post by simso » Fri Jan 06, 2017 10:28 pm
Forgot photos, from this
to this
johnparchem
Re: Buffing
Post by johnparchem » Sat Jan 07, 2017 1:34 am
great how to tutorial.
Re: Buffing
Post by kiwigeo » Sat Jan 07, 2017 2:15 am
When it come to gloss.....Simso's the Boss!! :mrgreen:
Re: Buffing
Post by Mark McLean » Sat Jan 07, 2017 7:21 am
Great tutorial Steve. The pictorial walk-through really gives a good instruction in the whole process. Do you pre-soak the paper for the wet sanding? If so, for how long?
Thanks, Mark
dshaker
Re: Buffing
Post by dshaker » Sat Jan 07, 2017 9:24 am
Very nice tutorial. Thanks! Any comments on doing the sides and neck?
-Doug Shaker
routout
Re: Buffing
Post by routout » Sat Jan 07, 2017 10:58 am
I put some thin craft felt between the block and paper helps to stop the pick up . :)
Re: Buffing
Post by simso » Sat Jan 07, 2017 12:30 pm
Thanks,
I'm actually not a pre-soak the grit person, I do u dersatnd the merits of doing that, but time is always of the essence.
That differs when I am using micro fibre pads, these I will pre-soak as I appear to get a better result.
Yes sanding the neck is so easy to go through the finish, I use a rubber backing caul with my sandpaper
Thanks for the positive feedback
