Dear ANZLF members,
Although I would love to purchase a drum sander, presently, it's beyond my budget.
Does anyone know of a business, in Brisbane, who could drum sand backs and tops to bring down to general thickness requirements?
I'm thinking a joinery or cabinet maker's business or Men's shed etc.
I know I could work things down entirely with a hand plane and I will certainly be putting the finishing on each board in this way but, I'm hoping to use that time elsewhere.
Oliver
Drum sanding service in Brisbane
- Steve.Toscano
Re: Drum sanding service in Brisbane
Hi Oliver, you could try Andrew at the Brisbane Guitar Making School. His offsider (Trent) is a member on the forums.
Alternatively, give it a go with your handplanes, it doesnt take very long at all and you will learn a lot throughout the process.
I have a drum sander and still do most of my back/side thicknessing by hand plane, with the exception of highly figured woods.
Once you are well practiced you may even find you are quicker doing it by plane then through the sander.
- lamanoditrento
Hi Oliver, Give Andrew a bell on 0418 569 019, the school is located Unit 5/101 Jijaws St, Sumner QLD 4074.
- J.F. Custom
Hi Oliver.
Clubs and men's sheds are an option as you alluded to, or perhaps some of the newer maker space type options such as "The Edge" or others, but you'd have to do some digging to see what equipment they have and the terms of use. Otherwise you could also try:
www.woodnyou.com
They are based in Coopers Plains. They are a workshop 'for hire' as such - you pay for the use of their equipment on a time basis. You can also have someone do it for you there for an additional fee I think. Depends on how confident you are with using the machinery - the better you are, the less it will cost as you'll get the job done faster!
I've no affiliation with them at all, but used their workshop when I first started out and did not have all the equipment myself. That was over 20 years ago now - the fact they are still operating suggests they are doing something right. They had wide drum sanders then and I imagine they still do. A call could confirm this and pricing for you.
Good luck.
www.woodnyou.com
Good luck.
Thanks everybody. I appreciate your advice.
Oliver
Oliver
