Black marks/stain in grain
Howdy All,
Just a quick (probably silly) question, I have an unfinished flame QLD maple cap on a guitar and I sprayed it with water to bring out the grain and wood colour and after the wood dried I was left with a black stain in the grain covering half of the guitar...what did I do..? Is it because I used tap water?
Cheers in advance
Cheers in advance
Re: Black marks/stain in grain
Can you put up a photo? Sounds like either something in the water or something water soluble on the wood that the dousing has spread around.
With water and after it had dried, you can see on the right hand side the staining isnt bad and I gave it a light sand wich seemed to work ok but there is still black in the flame so I stopped to see if I could find another solution rather than sand anymore..
That looks like staining due to a mix of iron and carbonate ions in your water reacting with the tannins in the wood (i.e. hard water plus iron plus tannins). A certain fix for that is to wash it down with a mild solution of oxalic acid in pure (de-ionised) water. Oxalic acid is available in crystal form from Bunnings as a deck cleaner. Don't use too much (a teaspoon of oxalic acid crystals dissolved in a cup of warm water is plenty) or you will end up with a red hue in the wood. Wash down afterwards with a mild acid solution e.g. white vinegar in pure water. You could try starting with a wash down of white vinegar in water and that may just do the trick. But if it doesn't, you now know what will work. Oxalic acid is a bit nasty, so observe the safety instructions on the container.
I was thinking the above but didn't think Queensland Maple was that high in tannins. I didn't consider high iron in the water.Trevor Gore wrote: ↑Wed Jul 24, 2019 9:59 amThat looks like staining due to a mix of iron and carbonate ions in your water reacting with the tannins in the wood (i.e. hard water plus iron plus tannins). A certain fix for that is to wash it down with a mild solution of oxalic acid in pure (de-ionised) water. Oxalic acid is available in crystal form from Bunnings as a deck cleaner. Don't use too much (a teaspoon of oxalic acid crystals dissolved in a cup of warm water is plenty) or you will end up with a red hue in the wood. Wash down afterwards with a mild acid solution e.g. white vinegar in pure water. You could try starting with a wash down of white vinegar in water and that may just do the trick. But if it doesn't, you now know what will work. Oxalic acid is a bit nasty, so observe the safety instructions on the container.
- Sassafras
Just a little aside, when I want to view the grain I spray with Iso Propal Alcohol you will find it at Bunnings it will high lite the grain then evaporate of with no residual effect. I hope you find this helpful. Cheers , Robert
Thank you All, I will give it a try and report back. I knew it was risky but was a little impatient... thanks again!
Hi All,
Sorry for the delay in responding, moved over to Perth for a new role.
The vinegar removed most of the stain but might have to try the harsher chems to clean it all up.
Cheers!
Cheers!
