I need to attach black celluloid binding to a new build (my first one hence the dilemma).
It is to be tight against black and white purfling so I don't want a glue line to show between them, so I need an adhesive for celluloid to wood that is available here in NZ.
I've seen some on here recommend Tarzans Grip (which is available at Bunnings) but which one do people use (there are several) and does it dry clear, brown etc?
Maybe there is something better to use? All suggestions gratefully received
Binding glue- which one to use
Re: Binding glue- which one to use
I used this for a dreadnought build 10 years ago. Its still on there!!
https://www.glueguru.co.nz/shop/SUBSTRA ... 146ml.html
If you're in Auckland this is the place to go for glue
Ps i used it because it was recommended by Stewmac as part of their kitset instructional dvd.
Users browsing this forum: Google and 69 guests
