Falcate Bracing question
Redbloke1956
Post by Redbloke1956 » Sat Jun 19, 2021 8:17 pm
Hi all, can anyone tell me why “The Primary braces overlay the Bridge plate and MUST BE assembled with the bridge plate USING THE SAME RESIN MIX”?
johnparchem
Re: Falcate Bracing question
Post by johnparchem » Sun Jun 20, 2021 12:39 am
The CF tow for the primary braces passes under the bridge plate. The primary braces are clamped on to the tow during the open time of the epoxy used to glue down the tow.
Post by kiwigeo » Mon Jun 21, 2021 2:02 pm
LOL....I've been gluing in the bridge plate/CF sandwich and primary braces as separate operations. I've been running the tow over top of the bridge plate. I obviously missed the relevant instruction in the The Book. Haven't had any issues so far.
Steve.Toscano
Post by Steve.Toscano » Tue Jun 22, 2021 10:15 pm
I do the same and instruct the students to do it this way too.
Although i i'm not useing CF in the bridge plate at all. INstead 2mm thick maple or rosewood glued with titebond. CF and primary falcates all go over the top.
