UV cure
Re: UV cure
Do you ever finish whole guitars Steve, or do you use it only for repairs? Any issues with fretboard edges or lacquer around the bridge on acoustics?simso wrote: ↑Tue Jun 22, 2021 10:06 pmYep, i use cure uv
https://www.cureuv.com/collections/uv-g ... ng-systems
Re: UV cure
I've recently used Solarez "I can't believe its not laquer!" for pore filling.
I cured it in the sun. It cures fast, cures hard. Sands easily, but it also can be easily pulled out of the pores too.
If I could apply it smoothly enough it would be a good finish since it's clear and glossy. I might try and level sand and polish it next time.
Re: UV cure
Complete resprays and first time builds have used it on, spraying and masking is no different, i dont however paint with the bridge on, i micro route the edge of the bridge and fit it over the top of the finish, same way taylor does
Re: UV cure
Solarez won't cure on dark woods in my experience. Excellent on mahogany and maple.joel wrote: ↑Thu Jun 24, 2021 8:43 pmI've recently used Solarez "I can't believe its not laquer!" for pore filling.
Re: UV cure
Good to know. I don't know of anyone who sprays gloss guitar with the bridge on - my concern if how the lacquer behaves when you remove it when you are going to glue the bridge on - as its only a mechanical bond. But if you've not had issues, that's good to know.
Re: UV cure
I dont remove the finish where bridge goes as i mask that area off when gel and clear coating, so its raw wood all the time, between flashing with the light, I peel the mask from the area, its not good to leave tape in when you are hitting it with the light
