Gluing help please.
David Herring
Gluing help please.
Post by David Herring » Tue May 10, 2022 10:14 pm
I am currently restoring an old Onyx electric accoustic guitar. It has a fibreglass body ( like the old Ovations) and A wood plastic laminated top. The wooden bridge has popped off easily and I'm not sure what is best glue to use to replace it. The top has quite a dip at front and hump at back. Top is very rigid and I suspect brittle and I dont think a bridge doctor will move it. Any suggestion please?
Re: Gluing help please.
Post by 56nortondomy » Wed May 11, 2022 4:31 pm
Sounds like maybe an epoxy job David, someone else might have an idea.
David Herring
Post by David Herring » Wed May 11, 2022 4:43 pm
Thats what I was thinking Wayne although others dont favour epoxy on bridges in case they have to come off again. Not sure if titebond will stick to plastic.
Post by kiwigeo » Wed May 11, 2022 7:02 pm
It'll stick...for about as long as it takes to undo the clamps :)
David Herring
Post by David Herring » Wed May 11, 2022 10:13 pm
Thanks Kiwigeo. What do you suggest?
Post by 56nortondomy » Thu May 12, 2022 4:21 pm
Epoxy on bridges isn't ideal but sometimes it's the only option, I've used it on bridges a couple of times when I've had to. I think in your situation your options are pretty limited. Wayne
Post by kiwigeo » Thu May 12, 2022 5:22 pm
If the top gluing surface is plastic then epoxy is probably your best bet. Not ideal for wooden tops as when there's a bridge failure it rips half the top in the process. A plastic top is a different scenario.
pkdz
Post by pkdz » Thu May 12, 2022 9:31 pm
I would be tempted to use medium CA glue.
This is from another forum to glue a bridge on a Formica top:
use just enough CA to cover the bottom of the bridge so there will be minimal squeeze out. glue it like you would with regular clamps and wood glue making sure to clean off any squeez out with paper towels. with the bridge clamped, you can use acetone to clean off the CA that has been left behind after clean off and has left a mess on the top. you dont have to worry about the acetone melting the top as it is melamine or whatever. NOTE : THIS IS SOMETHING YOU CANT DO ON A NITRO FINISHED TOP!!!
Paul
Post by Allen » Fri May 13, 2022 6:01 am
I'd also suggest the medium or thick CA. It is what Rich Turner used for gluing bridges to his Polyester finished instruments for years.
Post by kiwigeo » Fri May 13, 2022 8:53 am
What's the sheer strength of CA compared to epoxy?
David Herring
Post by David Herring » Tue May 17, 2022 11:56 am
Thank you all for your suggestions. I went with the epoxy before the ca suggestions came through. What a job even after masking. Anyway all done and restrung now. The electronics looked cactus and I had removed the piezo and made a new saddle to just have the guitar as accoustic. However after fiddling (I know nothing about electronics) I got the thing working again but have a lot of crackling when powered up. I guess after 40 odds years of dust it's not surprising. Any suggestions on a cleaner that wont cost me an arm and a leg. I mostly fix up classical guitars so wont need much. This guitar has had a lot of use. Grooves in the frets and troughs in the fretboard so I guess at some stage it must have sounded Ok
David Herring
Post by David Herring » Tue May 17, 2022 12:03 pm
Paul
I think I will try ca next time Paul. How do you pick a nitro finish. With my limited skills they all just look 'shiny'?
Post by kiwigeo » Tue May 17, 2022 12:35 pm
Any contact/pot cleaner should do the job. Whatever you do don't use WD40 or other "cleaners" high in distillate and other nasty solvents.
pkdz
Post by pkdz » Tue May 17, 2022 1:35 pm
David
I would try a very tiny bit of acetone under a tuner.
Paul
Post by kiwigeo » Tue May 17, 2022 7:44 pm
http://www.frets.com/FretsPages/Luthier ... etest.html
David Herring
Post by David Herring » Thu May 19, 2022 11:57 pm
David
Paul
Thanks Paul.
David Herring
Post by David Herring » Thu May 19, 2022 11:58 pm
Nice link Martin. Thnks
David Herring
Post by David Herring » Fri May 20, 2022 11:20 am
[img][/img
All finished and ready to go to a good home. Had not seen an Onyx before but looks like Ovation copy. Fixed all the crackling with cotton buds and Kleanium contact Kleen. Bridge is glued and not pretty but solid. Thanks everyone for your help.
David Herring
Post by David Herring » Fri May 20, 2022 11:46 am
