Gluing help please.
- Beefwood
Gluing help please.
I am currently restoring an old Onyx electric accoustic guitar. It has a fibreglass body ( like the old Ovations) and A wood plastic laminated top. The wooden bridge has popped off easily and I'm not sure what is best glue to use to replace it. The top has quite a dip at front and hump at back. Top is very rigid and I suspect brittle and I dont think a bridge doctor will move it. Any suggestion please?
- 56nortondomy
Re: Gluing help please.
Sounds like maybe an epoxy job David, someone else might have an idea.
- Beefwood
Thats what I was thinking Wayne although others dont favour epoxy on bridges in case they have to come off again. Not sure if titebond will stick to plastic.
It'll stick...for about as long as it takes to undo the clamps
David Herring wrote: ↑Wed May 11, 2022 4:43 pmThats what I was thinking Wayne although others dont favour epoxy on bridges in case they have to come off again. Not sure if titebond will stick to plastic.
- Beefwood
Thanks Kiwigeo. What do you suggest?
- 56nortondomy
Epoxy on bridges isn't ideal but sometimes it's the only option, I've used it on bridges a couple of times when I've had to. I think in your situation your options are pretty limited. Wayne
If the top gluing surface is plastic then epoxy is probably your best bet. Not ideal for wooden tops as when there's a bridge failure it rips half the top in the process. A plastic top is a different scenario.
I would be tempted to use medium CA glue.
This is from another forum to glue a bridge on a Formica top:
use just enough CA to cover the bottom of the bridge so there will be minimal squeeze out. glue it like you would with regular clamps and wood glue making sure to clean off any squeez out with paper towels. with the bridge clamped, you can use acetone to clean off the CA that has been left behind after clean off and has left a mess on the top. you dont have to worry about the acetone melting the top as it is melamine or whatever. NOTE : THIS IS SOMETHING YOU CANT DO ON A NITRO FINISHED TOP!!!
Paul
Paul
I'd also suggest the medium or thick CA. It is what Rich Turner used for gluing bridges to his Polyester finished instruments for years.
- Beefwood
Thank you all for your suggestions. I went with the epoxy before the ca suggestions came through. What a job even after masking. Anyway all done and restrung now. The electronics looked cactus and I had removed the piezo and made a new saddle to just have the guitar as accoustic. However after fiddling (I know nothing about electronics) I got the thing working again but have a lot of crackling when powered up. I guess after 40 odds years of dust it's not surprising. Any suggestions on a cleaner that wont cost me an arm and a leg. I mostly fix up classical guitars so wont need much. This guitar has had a lot of use. Grooves in the frets and troughs in the fretboard so I guess at some stage it must have sounded Ok
- Beefwood
I think I will try ca next time Paul. How do you pick a nitro finish. With my limited skills they all just look 'shiny'?pkdz wrote: ↑Thu May 12, 2022 9:31 pmI would be tempted to use medium CA glue.
Paul
Any contact/pot cleaner should do the job. Whatever you do don't use WD40 or other "cleaners" high in distillate and other nasty solvents.David Herring wrote: ↑Tue May 17, 2022 11:56 amAny suggestions on a cleaner that wont cost me an arm and a leg.
David
I would try a very tiny bit of acetone under a tuner.
Paul
Paul
http://www.frets.com/FretsPages/Luthier ... etest.htmlDavid Herring wrote: ↑Tue May 17, 2022 12:03 pmHow do you pick a nitro finish. With my limited skills they all just look 'shiny'?
- Beefwood
- Beefwood
Nice link Martin. Thnkskiwigeo wrote: ↑Tue May 17, 2022 7:44 pmhttp://www.frets.com/FretsPages/Luthier ... etest.htmlDavid Herring wrote: ↑Tue May 17, 2022 12:03 pmHow do you pick a nitro finish. With my limited skills they all just look 'shiny'?
- Beefwood
[img][/img
All finished and ready to go to a good home. Had not seen an Onyx before but looks like Ovation copy. Fixed all the crackling with cotton buds and Kleanium contact Kleen. Bridge is glued and not pretty but solid. Thanks everyone for your help.
- Beefwood
Users browsing this forum: No registered users and 198 guests
