Soundboard joining
- Beefwood
Soundboard joining
Hi All
Another beginners question , I have Adirondack from Old Standard Wood in the US
I found John at OSW very helpful he even asked me if the guitar was being used mostly with a pick or finger style . It will be used most of the time finger style and he selected a set to suit
.It is light stiff and has a real ring to its tap tone so I am looking forward to using it .The problem I have is the sides of each plate are not straight , where it will be glued is straight of course but the outside edges have an irregular guitar shape . I found it easy to join my previous Englemann plates which were oblong but I am wondering how to approach this , I need to get it right the plates were expensive and I can’t afford to waste them .
I am hoping that someone on the forum has already had this problem and solved it satisfactory.
Peter Lynch
Peter Lynch
Re: Soundboard joining
Not exactly sure what the problem is here Peter. As long as the two plates have a long side that can be joined and the top profile fits the plates you're ok. Top and back sets will often come cut so they just fit a template for the designated guitar they're advertised to fit.
Non rectangular top plate sets may present an issue with some top gluing jigs but this can usually be dealt with using packers and wedges.
I think what Peter is worried about is how to get clamping pressure pushing in from the edges - to get the centre join together. If the outside edges are straight you can use some sort of straight edge to push against, but maybe he is wondering how to do that if the outer edges are already cut with a curved shape?
I use the "tent method", which is shown in the first video below. If you use nails as the thing that the outer edges push against, as in this video, it actually doesn't matter if the edges are straight or curved. In the video they are straight edges, but it works exactly the same if they aren't straight.
https://www.youtube.com/watch?v=omCCUIcNhYE
You could also use the method that Nigel demonstrates in this video. Again, doesn't matter the shape of the outer edge. Hi Nigel - I hope you don't mind me putting your nice demo up here?
https://www.youtube.com/watch?v=URSztnmmOx4
I use the old fashioned string and wedges method - couldn't find a photo of it in use but you can probaly see how it goes or find some other pics. It is a commonly used method.
It will accommodate quite severely non straight outer edges, particularly if you arrange the framework the right way.
Good luck
Good luck
Tape tent method is my go to for all soundboard and backs. Especially when the outer perimeter isn't straignt. Often I'll cut to body shape in order to get two instruments out of a single plate. I've joined over 500 instruments this way
Simple and fast and nothing more than some sturdy masking tape required.
Mark McLean wrote: ↑Tue Sep 06, 2022 10:48 pmI think what Peter is worried about is how to get clamping pressure pushing in from the edges - to get the centre join together. If the outside edges are straight you can use some sort of straight edge to push against, but maybe he is wondering how to do that if the outer edges are already cut with a curved shape?
No problem, I was going to post it myself yesterday but couldn't find my login details.
- Beefwood
Thank you once again , I get it !
Thank you everyone I really appreciate the help , I normally use straight slats of wood to push against using a variation of the tent method . I couldn’t quiet get my head around pushing against edges which are irregular but I can understand how to do this now
Once again , thank you
Peter
Peter
With a tourniquet style jig like the one I use the outside shape of the plates doesn't really matter as you have multiple sets of rope pulling the plates together.
Users browsing this forum: No registered users and 225 guests
