How to create a vintage amber stain ?
donnyb
Post by donnyb » Mon Oct 30, 2023 8:00 am
Hi ,
I like restoring 70's Yamaha guitars, but have not found a very close vintage amber stain to add to the acrylic lacquer spraygun finish.
I use Dulux Prooftint stains, of which I have a lot of different colours. For amber, I mix yellow, (golden teak), red (maple) and a bit of brown, but usually end up with a colour that's either too yellow or orange. I guess I have just not got the right ratios or am missing a colour in the mix, but man, I have tried a lot.
The USA has vintage and medium amber solvent based stains, but wont ship to Australia due to flammability.
In the photo herewith of a FG151B 1979, the colour I'm after is the darker amber areas on the soundboard.
https://imgur.com/sTLoNpe
Hoping someone has mastered it, or can point me to a premixed amber stain that's available in Australia and most importantly, compatible with spraygun application acrylic lacquer.
Cheers and thanks for reading.
asgilbert
Re: How to create a vintage amber stain ?
Post by asgilbert » Mon Oct 30, 2023 8:48 pm
Hi Donnyb, I got some of Crimson Guitars in UK. It is water based.
https://www.crimsonguitars.com/products ... ng-stains/
donnyb
Post by donnyb » Wed Nov 01, 2023 12:46 pm
Thanks Blackwood.
I don't think water based will mix with acrylic or nitrocellulose lacquers though (?).
Post by 56nortondomy » Wed Nov 01, 2023 4:26 pm
Stewmac stains mix with water and lacquer, I've used it many times. Wayne
matthew
Post by matthew » Sat Apr 27, 2024 3:27 pm
this is an old thread by now and you've probably solved your Amber problem but looking at the recipe you've described I would just be adding a touch of black.
each time you add brown to a mix to make it darker you're actually adding a bit of red, so it's very easy to go too red with a mix that's got red in it already. Black usually has a bit of blue in it which takes off the red and makes it darker.
i do a lot of colour matching and touch up with spirit stains. I can get 99% of the shades I want with these four tints.
Users browsing this forum: Google and 51 guests
