Neck reinforcement
Pat.Hawkins
Neck reinforcement
Post by Pat.Hawkins » Wed Jun 26, 2024 9:38 am
Hi Folks,
I plan on dropping a 300mm length of carbon fibre into a baritone ukulele neck. It's roughly 3mm x 9.5mm
Is this a good idea?
If I do, should it be installed as a dry fit or should I flood the channel with epoxy and lock it in?
peter.coombe
Re: Neck reinforcement
Post by peter.coombe » Wed Jun 26, 2024 10:00 am
Use Epoxy.
Post by kiwigeo » Wed Jun 26, 2024 10:59 am
I haven't used CF rods in my steel string necks for a while but I used to always epoxy them in.
Robert Gleason
Post by Robert Gleason » Thu Jun 27, 2024 8:16 am
Epoxy them in wth good epoxy, not the 5 minute kind. Also, add a couple mm wood filler strip over the top so that you still have a little working room to plane the neck to straighten it or put relief in.Bob
Pat.Hawkins
Post by Pat.Hawkins » Sat Jun 29, 2024 10:29 am
Thank you for the advice. I've only ever kept 5 min. epoxy on the shelf but for this job I'll look for something better. Also, If I have a cover strip that's a bit proud, I'm not confident I could get a good finish with the hand plane so either the jointer or sanding board?
I'm just picturing that awful glue line running down the side of the fretboard where I've rolled the edges of the neck. :) Cheers
Post by kiwigeo » Sat Jun 29, 2024 10:46 am
I use Techniglue epoxy.
https://www.carbatec.com.au/techniglue- ... -60a-500ml
A light plane over the centre strip will get it flush. Finish the job with sandpaper and a hard sanding block....or run the neck blank over a large sanding board.
Pat.Hawkins
Post by Pat.Hawkins » Sat Jun 29, 2024 3:56 pm
Thanks again,
we have a Carbatec rep. make regular visits . I'll order some and avoid shipping costs.
While I'm here......... we should share our rookie "learning experiences" right?
I've just bandsawn the tapered edges off the neck and haven't routed the rod channel yet.
Ouch!
I guess I can temporarily stick the tapered waste edge back on.
Post by kiwigeo » Sat Jun 29, 2024 7:24 pm
Ouch!
Yep.....thats pretty much what Ive done in exactly the same situation. A couple of bits of wood glued to side of neck that will register against router table fence. If using a hand held router then glue a full strip of wood along one side of neck and plane to required dimension.
