Why don't we lacquer bridges?
Is there a musical reason why we don't, as a rule, apply finish to our bridges? I've always followed the crowd and simply used lemon oil or similar.
I've just made a laminated bridge out of maple and ziricote for a steel string that would really pop under a lacquer and I'm wondering if players would have a problem with this.
My instinct is 'No', most guitarist can transition between a wooden bridge to a steel bridge on an electric without a problem. But, is it likely that the extra friction on a lacquered bridge would lead to plating difficulties?
Peregrine Guitars
Peregrine Guitars
Re: Why don't we lacquer bridges?
I french polish my instruments and have always finished the bridges on my instruments..classicals and steel strings.
The area around the string holes takes a bit of a beating during string changes so I could understand that being a possible reason for not finishing a bridge.
No real knowledge, but I always thought tradition. Finish Classical but not steel strings. I sort of cheat with steel stings and wipe on refined linseed oil (small bottle bought at art store). It wets the grain but is very thin.
I’m with John above, I’ll wipe on boiled linseed oil or some tung oil.
- Robert Gleason
- Kauri
On acoustic guitrars and ukes I shellac my bridges with a coata of 4# cut and steel wool most of it off, leaving just a little in the pores. Then i give it a coat of Renaissance wax and buff it lightly.
- Taffy Evans
Hi, I'm in the do not lacquer my bridges camp. I like the look of natural-looking timber, especially as it is often a nice piece of hardwood.
I use a Mirotone Teak wax called Alna 738. It has a different name now, I bought a liter tin of it over 30 years ago and am still using it. It brings out the grain features of the timber and has a nice soft satin look. When I do repairs I use it on dry fingerboards and bridges, so it gets a lot of use.
Thanks for all the replies.
The consensus seems to be that we don’t do this for aesthetic reason and not one of practicality.
Peregrine Guitars
Peregrine Guitars
Users browsing this forum: No registered users and 41 guests
