Weld on cement
Weld on cement
Hi all
I am still finding my way through this guitar kit and it seems that at every turn there is a problem to solve. I must say though that this is not a bad thing but one that is stimulating in a frustrating way.
My latest problem is finding an appropriate substitute for theweld on cement StewMac recommend .
I went to a local hobby shop and asked for weld on cement and they looked at me sideways. Uhh?
What is the local substitute for this adhesive? StewMac recommend it for gluing bindings, etc.
Jim Latham
Tecoma
Tecoma
- graham mcdonald
- graham mcdonald
Don't think about using Titebond if the bindings are plastic. If the Weldon 16 isn't readily available it might be worth checking hobby shops for solvent type glues, the things that stick together plastic model planes and cars, if you are using ABS plastic bindings and I think that is what the StewMac kits are including.
The other possibility is good old fashioned Tarzans Grip (I think it is still available) which has that same sort of solvent glue smell. What you are looking to happen is for the glue to melt/dissolve/soften the bindings just a little while you hold it to the rebate on the body. A bit of testing might be in order.
Some people use superglue for plastic bindings. No direct eperience, but I would be a little concerned about the brittleness of the bond. That said, lots of people use it successfully, at least anecdotally from discussion groups.
With any of the solvent glues, some ventilation is good unless you really want the buzz from the solvents
graham
graham
Graham McDonald
- sebastiaan56
The label on my tube of Weld-On #16 includes the advice "If inhaled, move into fresh air. If not breathing, give artificial respiration." I think that gives a good indication of what you'll be dealing with.With any of the solvent glues, some ventilation is good unless you really want the buzz from the solvents
I'll say it again: read the warnings on the label before you use it!
Weld-on is solvent based and easy to use but everyone is right that ventilation is required.
Also it shrinks back considerably in the first 24 hours and this is the solvents escaping...... So after using it be sure that the guitar has a place to cure that is free of humans and pets.
Lastly don't attempt to scrape back for at least 24 hours, 48 is better, because it shrinks so very much. Once all the shrinkage........ is over you can scrape level.
fletch (flěch)
tr.v. fletched, fletch·ing, fletch·es
To feather (an arrow).
There was a time I was seriously into archery. Made my own gear, well except the bow, but I was working on that. Then I injured my shoulder and we move up here. The shoulder heal, mostly, but I couldn't justify the annual cost of joining a shooting club to have access to their range for an every other weekend round and the daily rate is just robbery.
I'm trying to build a guitar instead.
Martin, I don't think I want to know where your mind went to.
