Gore/Gilet/ Concepts & Falcate Bracing in a Uke Build
Clancy
Re: Gore/Gilet/ Concepts & Falcate Bracing in a Uke Build
Post by Clancy » Mon Mar 04, 2013 9:07 pm
Glad you enjoyed it Jim.
Since you re-birthed the thread, and since I've had a few queries, here's a bit of where I've gone to with all this.
Btw, as I'm essentailly a lazy git, the following is almost directly copied from a reply to a PM from Paul (Ozwood).
After a while of playing the falcate uke I decided that the top was braced too tight.
I got inside it by breaking the end off a hacksaw blade and putting a long, thin bolt through the hole.
Using this I thinned the main falcate braces a bit, in the area between the bridge & the sound hole.
I think it now sounds great and have recieved many comments as such.
I regularly get told that it doesn't have as bright a sound as a regular uke, more a sweeter sound that leans towards a guitar tone. (The fact that I use a Low G probably adds to this perception).
But it doesn't lose anything in volume, with it holding it's own ground at my uke club nights against around 35 other ukes played at once.
I have made 4 more falcate concert uke tops using what I learned from the first instrument.
Of these, two ukes have now been completed.
The top resonance of the original uke was 318Hz.
After re-working the bracing it's now 313Hz.
The top resonance of the second uke is 304Hz.
The top resonance of the third uke is 293Hz.
But to the ear they sound identical to the original, which is my main aim.
The differences between the original and the new tops are
- I did not use a bridge patch.
- I did not put cf rove on/under the little horizontal braces so I could sand them down or remove them completely if I wanted (but I haven't)
- I didn't put cf rove on top of the secondary falcates
- I made the main falcate braces less stiff between the bridge & the soundhole
And because we all love pictures, and because we all love Tim's Tiger Myrtle, here's how I made use of one of his 'special sales' on the third falcate uke.
Cheers all.
24022013244 (Medium).jpg (53.79 KiB) Viewed 1683 times
24022013240 (Medium).jpg (86.72 KiB) Viewed 1683 times
Post by Trevor Gore » Mon Mar 04, 2013 10:00 pm
Nice, Craig.
Thanks for posting the resonance data. All up, it sounds like it's been a pretty interesting journey!
blackalex1952
Post by blackalex1952 » Mon Dec 04, 2017 12:55 pm
What a great thread...don't loose this, guys! Is there a 2017 progress report on your builds, Clancy?
blackalex1952
Post by blackalex1952 » Mon Dec 17, 2018 10:21 pm
A great thread..thanks for resurrecting it. Only two questions:
It's hard to get my 8yr old son's attention with anything these days.
But when I showed him the video of the herbs 'dancing' on the uke, he said "Cooool. Where do you get those dancing herbs?"
Yes...where did you get those dancing herbs, and were you smoking them? :mrgreen: Cheers! Ross
Users browsing this forum: No registered users and 31 guests
