bracing
- Gidgee
Re: bracing
So I'm about to start my next guitar build and I want to use some NZ timbers on it , specifically the top the neck and the bracing.
I'm using black walnut for the back and sides and I wanted to use Pauduk for the the back bracing for some colour and strength but obviously that's not a kiwi timber and is super expensive to get here so does anyone know of a nice looking strong bracing timber either from NZ or Australia?
Re: bracing
What you're looking for in bracing wood is something that is light and stiff. I tend to stick to spruce as it fits the bill on both counts.Mikeson1510 wrote: ↑Wed Aug 02, 2023 8:52 amSo I'm about to start my next guitar build and I want to use some NZ timbers on it , specifically the top the neck and the bracing.
Re: bracing
I cut all my braces to the same rectangular cross section 8mm by 12mm in a way that the end grain show the grain lines going vertically.Mikeson1510 wrote: ↑Wed Aug 02, 2023 8:52 amSo I'm about to start my next guitar build and I want to use some NZ timbers on it , specifically the top the neck and the bracing.
I then clamp one end and deflection test the length of the blank.
The least flexible ones are my preferred. Usually spruce and it has lower density.
Peregrine Guitars
Peregrine Guitars
Re: bracing
Mangeao for the top and bracing.
Tawa or tairere for the neck
If you find a source of mangeao please let me know.
- Gidgee
Re: bracing
Thanks Andos,
I managed to get my hands on some tararie for the top and neck, just have to get my hands on some good bracing timber
