Another Router Blooper
- Taffy Evans
This happened last week, lucky I notice the sound of the router change as the bit slipped down, and lucky it happened where it did.
Re: Another Router Blooper
Those dastardly routers. Can't live with em, can't live without em.
Whoops, happens to us all unfortunately, what frustrates me is it always happens closer to the end of the job rather than at the start
Nice save Taffy
I noticed you have laminated the upper brace, is it for extra stiffnes?
Matt
Matt
- Taffy Evans
Hi Matt, no just saving my brace wood, I did not want to cut into the good stuff for this brace and thought I'd do something different to get what I wanted.
I nearly got a bigger sound hole, if had not noticed the change in depth.
Scary. One more reason than just the noise to not use mines very often. Although, my problem is usually to get the bit out of the collet when I'm done!
- Nick Royle
- Wandoo
I'm sure you're far more experienced than I but that trouble stopped for me when I followed advice and stopped letting the bit "bottom out" in the collet. Wrong phraseology I'm sure but I now drop it in all the way, then hold it up a fraction while I tighten the collet.charangohabsburg wrote:Scary. One more reason than just the noise to not use mines very often. Although, my problem is usually to get the bit out of the collet when I'm done!
Thanks for the advice Nick, I'll try to think of it next time I'll use a router.
You may be wrong though regarding my experience, at least the one with routers. I use those screaming dust-throwers only about twice per year. But although I almost hate them they come in quite handy now and then!
Even if it wasn't the root cause of the problem position of the cutter shaft in bthe collet is important. I also make sure I keep my collets clean using a cleaning kit that came with my Trend T5 router. Especially important when the router is sitting upside down in a router table.Nick Royle wrote:I'm sure you're far more experienced than I but that trouble stopped for me when I followed advice and stopped letting the bit "bottom out" in the collet. Wrong phraseology I'm sure but I now drop it in all the way, then hold it up a fraction while I tighten the collet.charangohabsburg wrote:Scary. One more reason than just the noise to not use mines very often. Although, my problem is usually to get the bit out of the collet when I'm done!
- Taffy Evans
I have a Makita router that I have mounted as a overhead pin router, must have had it since the early eighties, and it will not hold the 1/4" or metric shaft bits any more, they slide down. The 1/2" - 12mm bits are fine [uses no collet] Iv'e done all sorts of cleaning and even contacting Makita but it looks like an expensive fix. Used to be able to get Imperial and metric collets but I cant find them now.
Good tip about the placement of the bit in the chuck, thanks.
- Nick Royle
- Wandoo
I also definitely have a love/hate relationship with routers. I just pattern [table] routed 16 layers of 18mm ply for two OM-ish moulds and I pretty much hated every second of it! It's on the table that they really worry me, I feel a bit better when I'm holding on to the thing... But I've done my first three guitars' binding channels on a router table jig and don't much fancy doing them by hand!charangohabsburg wrote:Thanks for the advice Nick, I'll try to think of it next time I'll use a router.
My old triton router damaged many guitars until I found out if I bought a better quality collet it would solve the problem.
Google Gifkin collet and it may solve a few problems. Worth the money.
Users browsing this forum: No registered users and 254 guests
