Build a mandolin
routout
Re: Build a mandolin
Post by routout » Sun Mar 19, 2017 9:16 am
Looking good there Mr Rocket :)
Post by rocket » Mon Apr 17, 2017 5:04 pm
A bit of progress on the A style.
Looks like I've loaded the pics out of sequence but I think you'll get the idea
Post by kiwigeo » Mon Apr 17, 2017 7:55 pm
Looking good Rod. Where did you buy the K and K pickup system?
Post by rocket » Fri Apr 21, 2017 9:34 am
Got the box closed and ready for purfling and binding, nice tight radius around the button!!!'
Also installed the K+K.
Rod
Post by ozziebluesman » Fri Apr 21, 2017 1:36 pm
Watching with great interest Rod.
Looks a treat!
Post by rocket » Sat Apr 22, 2017 1:27 pm
Used hhg for the back and binding same, a bit messy but got that curly maple binding on now, clean up and scrape the recurve.
Post by rocket » Fri Apr 28, 2017 5:41 pm
A style is getting some grain fill and I've got the F back on the bench.
Cheers Rod.
Post by kiwigeo » Fri Apr 28, 2017 7:11 pm
Looking good Rod.... :cl :cl
Post by Mark McLean » Fri Apr 28, 2017 9:33 pm
That is completely schmick. Very clean and lovely! Are you sure you haven't done this before.....
Post by Mark McLean » Fri Apr 28, 2017 9:42 pm
Hey Rod,
You have put that wedge-shaped inlay into the top, and the matching sound-hole binding. Is that just because it looks good (it really does, by the way), or is there a story to tell there?
Post by rocket » Sat Apr 29, 2017 1:42 pm
You picked it Mark, yeah a moment of stupidity, impatience saw a bit of butchery occur to the otherwise faultless spruce top and rather than try to patch, fill I elected to create a theme with the figured Blackwood to match the tail graft, peghead veneers, back inlay and sound hole bindings.
Cheers.
Post by rocket » Mon May 22, 2017 7:01 pm
A bit of progress, on to the finish inch stage, base coats are on and ready to apply gloss top coats
Rod
Post by rocket » Mon Jan 15, 2018 1:50 pm
Well a bit has happened since I last posted on this thread, not long after those last pics were taken I dropped the little sucker and split one side from tail to neck. Consequently I swore I’d not build any more, well that wasn’t true coz here I am with a nearly finished mando, check it out!!!
Post by Kamusur » Tue Jan 16, 2018 6:50 pm
That's a bloody nice finish Rod, well done.
Post by rocket » Tue Jan 16, 2018 9:47 pm
Thanks Steve, i still have the F style on the go or should i say ready to be on the go!!
Post by rocket » Tue Jan 23, 2018 6:53 pm
Finished
Users browsing this forum: Google and 56 guests
