Southern Cross open back banjo Uke Tenor scale.
The neck is Heart Rimu with a Kahikatea and Purple Heart stripe.
The body is a block construction using Kahikatea with a feature ring of Purple Heart, ninety-six blocks in all.
Fretboard Purple Heart with Kahikatea position markers, Gotoh planetary geared tuners.
Latest Build
Latest Build
Life is not measured by the number of breaths we take,
but by the moments that take our breath away.
Kind Regards
Southern Cross banjo Ukes
New Zealand
Kind Regards
New Zealand
Re: Latest Build
That looks great Dennis. I have never been too fond of Purple Heart before, but there is something about the "out there" brassiness of a banjo that makes purple wood seem appropriate. The whole design comes together very well. And your building is obviously very good.
I have never heard of kahikatea. What can you tell us about it?
Re: Latest Build
Kahikatea
also called New Zealamd white pine
New Zealands tallest tree at 60 meters and around 2.5meters at the base. A straight even grained softwood with a white sapwood and pale yellow heartwood. Prone to borer after milling. Easy to work and bend. It used in boat building. Also good for cutting boards and general kitchenware as it has very little smell and won't taint food.
Quite common and a realitively cheap timher.
Not recommended for instrument building because of its suseptibility to borer attack.
I've used it as a violin soundboard with quite pleasing tone and looks. While not up there with sika i'd use it again. Helps to keep costs down while I learn the trade!
and as long as you keep playing it the borer won't settle in it
Re: Latest Build
Someone has quoted Wikipedia on the Kaihikatea so no need to eleborate other than borer likes all NZ timber, Rimu, Kauri etc, so I don't concern myself with it, I just don't allow borer on the property.Mark McLean wrote:That looks great Dennis. I have never been too fond of Purple Heart before, but there is something about the "out there" brassiness of a banjo that makes purple wood seem appropriate. The whole design comes together very well. And your building is obviously very good.
Hi Mark,
Yes I think the solid body build of banjos, banjo ukes suits woods that may suit guitars, ukes etc. I love Purple heart as you can see . Makes great fretboards.
Kind Regards
New Zealand
Kind Regards
New Zealand
Users browsing this forum: No registered users and 203 guests
