I'm gearing up to spray finish a guitar with mirocat and usually begin with a light coat of blonde dewaxed shellac. I have a bag of blonde dewaxed flakes i bought 6 years ago that are all clumped together in a solid blob. A bit of a search indicated this is still usable - best to break it up a bit (blender??) and use denatured alcohol.
Just checking that u guys agree with that and if u know where i can get better quality metho in melbourne if the bunnings stuff isn't good enough.
Thnx. Frank
'Old' shellac flakes
Re: 'Old' shellac flakes
Not sure about how you'll go with those flakes Frank. Mix up a bit and put a dab onto some glass..it should be fairly hard in around 20 minutes. If it's still soft then I'd ditch the flakes.
What Martin said.
I get my metho from a local industrial cleaning supply company. 4 liters for around the $30 mark and it's way better than the Diggers brand from Bunnings.
There is a lot of debate on the net about melting old flakes I have a couple of old batches and tried to melt it without a great deal of success,however I did have luck with button lac for some reason the method they use must be different ? . I went to a flooring company and bought pure metho he said why it's the same as diggers 100% meth.
Button lac is generally less refined and contains wax and has less surface area to oxidise? than flakes.
Dewaxed blonde flakes have the shortest shelf life.
Creers man that was what I was looking for flakes are super thin.
- 56nortondomy
I get my 100% metho from Paint spot, there's plenty of them around, most of them sell it but not all just check first. Brand name is Sceneys. Wayne
Users browsing this forum: Google and 240 guests
