The 5 minute fretboard
- HTS Manufacture Fretboard.JPG (169.47 KiB) Viewed 16030 times
Re: The 5 minute fretboard
Genius again Steve.
I always radius and flatten my fretboards when they are glued in place. Your method would still allow this to happen.
Ta.
Ta.
Peregrine Guitars
Peregrine Guitars
Interesting to see how the Pro's do it, great tutorial.
Col
Col
I also do it by hand and a caul once its fitted to the guitar, this is just I guess you could say, roughing it out
Nice one I have a similar set up ,I get close to the thickness shoot the fret slots in and sand radius on the belt they are extremely accurate .
Thnx Steve. How do u do the final taper?
I use my saw bench and keep nudging till i get to my pencil line!! Accurate enough but terribly inefficient and not the approach of a craftsman!
Can you clarify the terminology for me, the final taper?,
Apologies - by taper I mean, 1-11/16" at nut end and 2-1/8" at the 12th fret.
Awesome,
I attach it to the neck its going onto with a couple of 1mm drill bits, then using a razor blade, I trace the neck shape out from underneath onto the fretboard, then I belt sand it up to the line, refit the fretboard and then i tweak final dimensions with some sandpaper attached to a flat stone, my flat stone is a 1metre by 1 metre 100mm thick granite block
I use a scribe and chalk as an indicator for the lines marked helps my old eye sight the cut off brads work well i feel ,nice explanation Mr simso.
You must have some pretty ripped biceps there! Probably only on one arm like a Venetian gondolier!my flat stone is a 1metre by 1 metre 100mm thick granite block
-Ross
Im slow, but finally worked it outblackalex1952 wrote: ↑Tue Nov 28, 2017 1:20 pmYou must have some pretty ripped biceps there! Probably only on one arm like a Venetian gondolier!my flat stone is a 1metre by 1 metre 100mm thick granite block
-Ross
Ok - so u and others shape neck before gluing fingerboard. The books i learned from attach fb first then carve neck. So now i have to consider benefits of change of approach!!
Thnx.
Thnx.
No need for you to change your approach, you forget, I replace fret boards on guitars that are already finished, that is they are painted / lacqered and so forth
Guitars that I build, I definetly shape them on the neck as well
Users browsing this forum: No registered users and 129 guests
