White purfling strip
Cutty
Post by Cutty » Sat Dec 08, 2018 8:45 am
G'day folks, been a casual observer for a while and this is my first post so be gentle :)
On my next project I have a binding strip down the back with a white strip either side. The back binding will be the same strip so the white on the back will match the back strip. I then want to continue the strip into the end graft but the graft will be wider than the binding strip.
I figured I'd just get a plain white purfling strip and use that but there doesn't seem to be anywhere that sells just a plain white strip (that I could find anyway). So the question, can I make my own and if so, what material would I use to do that?
Re: White purfling strip
Post by kiwigeo » Sat Dec 08, 2018 9:05 am
I've used strips of maple wood veneer as well as fibre veneers..I usually get them from LMI: https://www.lmii.com/150-fiber-veneers
You could also get some W/B purfling and carefully scrape off the outside black layer leaving the white.
blackalex1952
Post by blackalex1952 » Sat Dec 08, 2018 9:26 am
I go to a veneer supplier and donate to the "Christmas party" a small sum of cash and the storeman shows me lots of nice veneers that I can choose from. One simply needs to ask the right person in the right business. Cheers! Ross
Post by 56nortondomy » Sat Dec 08, 2018 2:38 pm
I buy white and black fibre veneer sheets from RC tonewood it's pricey with post but lasts for years. Wayne
demonx
Post by demonx » Sat Dec 08, 2018 4:13 pm
I’d use maple veneer as suggested above.
It’ll be much friendlier during the sanding process. I’ve had issues with 0.5mm ABS plastic melting when I sand as it heats and softens so fast, then it’s a pain in the rear to repair, whereas veneer is easy to glue and won’t have the sanding problem.
blackalex1952
Post by blackalex1952 » Sat Dec 08, 2018 5:25 pm
Veneer can be stabilised with a size coat of thin HHG, then it can be worked and sanded if there are problems with the material. Cheers! Ross
demonx
Post by demonx » Sat Dec 08, 2018 7:58 pm
I laminate with veneers all the time and with the hundreds of guitars I’ve built I’ve never had to stabilise any. Just glue it up with titebond and carve away.
Cutty
Post by Cutty » Mon Dec 10, 2018 11:48 am
Thanks for that tip. To date I've only used domestically sourced timbers.
What, if any, are the issues with importing wood from overseas? Any problems with customs etc.?
Post by kiwigeo » Mon Dec 10, 2018 1:24 pm
Veneer wont cause you any issues. AQIS usually only get interested if your wood has bark and/or bugs on it.
Post by 56nortondomy » Mon Dec 10, 2018 5:25 pm
Martin is right, there's no problem bringing in most guitar timber, I've never had any issues. The only time I had stuff confiscated was when I bought some Tagua nuts, which are a completely different story. ( that was a $16 lesson not exactly the end of the world :lol: ) Wayne
Post by Mark McLean » Wed Dec 12, 2018 6:46 am
pic 9.JPG (205.15 KiB) Viewed 16928 times
This is maple veneer as purfling with cocobolo binding strips. Very simple to cut from sheets with scissors. Glues, scrapes and sands well. I bought it in Sydney. I am sure you would find a supplier in Adelaide.
Post by 56nortondomy » Wed Dec 12, 2018 4:42 pm
I got 10 sheets of sycamore veneer from Barry Kerr which I use for different things, ALS sell maple veneers natural and coloured.
https://luthiersupplies.com.au/luthier- ... neers.html
Cutty
Post by Cutty » Thu Dec 13, 2018 11:00 am
Thanks Wayne,
I looked on ALS originally but was searching for purfling so didn't find these.
Cheers!
Iain
Users browsing this forum: Google and 63 guests
