Bad Router Day
TallDad71
Bad Router Day
Post by TallDad71 » Sat Mar 16, 2019 4:21 am
Everything was going so well until it wasn’t!
I was cutting a binding channel 1.5mm around the lower bout of the top of the guitar with my router. The guide bush worked itself loose in the blink of an eye, I had two choices, quickly avert my gaze or risk a guide bush in the face.
I averted and can now clearly see the damage caused by the router bit gnarling inside the top. I have patched up the damage with a 2cm square patch but it looks bloody atrocious.
Does anyone have any magic method for making it more camouflaged?
Peregrine Guitars
demonx
Re: Bad Router Day
Post by demonx » Sat Mar 16, 2019 8:21 am
Pics?
P.S. We’ve all had bad router days. I myself have had many. Luckily it’s always only been timber damaged and not flesh.
Re: Bad Router Day
Post by Mark McLean » Sat Mar 16, 2019 9:00 am
Commiserations. This is why the sunburst finish was invented.
Re: Bad Router Day
Post by 56nortondomy » Sat Mar 16, 2019 6:48 pm
Maybe an opportunity for an inlay, of course it depends on the position. Wayne
seeaxe
Re: Bad Router Day
Post by seeaxe » Mon Mar 18, 2019 3:47 pm
Been there, done that. Mine was on a cedar top. I patched it with a piece from the same top but after several years it still sticks out like the proverbial dogs bollocks. Its pretty much the first thing I see whenever I pick it up.
In hindsight I might have been better off to have put paua shell or something equally distinct from the top, following the "if you cant hide it make it very obvious" theory.
Good luck whatever you do.
Fisherman
Re: Bad Router Day
Post by Fisherman » Tue Mar 19, 2019 12:45 pm
top or bottom of the guitar? if the top perhaps install an armrest ..
Bottom, i would probably start on a new top - sorry. If there is a good invisible repair i would love to learn it too!
Users browsing this forum: No registered users and 231 guests
