Here is the latest Luthier Tips du Jour video. - In this video I show how to use the LMI rotary plunge tool assembly to install a rosette.
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
youtu.be/61_Hgvom6Ms
New Luthier Tips du Jour video - Rosette installation
- ANZLF Approved Supplier
- Joseph Jones
Re: New Luthier Tips du Jour video - Rosette installation
Thanks Robbie,
I’ve just put the rosette in my first build the other day. I used a medium size router and a 3mm spiral bit. It worked, but no where near as quick and easy a in the video!
Do you recommend using a circle cutter in a drill press? Just wondering your thoughts on that method.
Joseph
Joseph
Glad you found the video useful. Some folks do use the drill press cutter but things can go wrong real fast. I have had tearout using that method in the past. The tool spinning around can also be intimidating.
What are your thoughts if I may Robbie, on installed Rosette areas Buckling under string tension, is that in your view more to do with the sides buckling or lack of strength under the rosettes from the inlay process or something entirely different
Definitely a lack of structural integrity and I would say it is in the top. I have made a guitar out of cardboard back and sides and the top has not buckled.
youtu.be/_elx2OvWN58
Nice vid. Sounded pretty good for a cardboard sides and back.
I actually have a tricky one in at the momment for repair, ovation 12 string with cutaway, the top is folding under tension at the rosette area adjacent to the cutaway, seeing your post made me rethink and question the why.
Users browsing this forum: No registered users and 254 guests
