Fibre Sheet for side lamination
lacrombie
Post by lacrombie » Sat Dec 14, 2019 11:10 am
Hi,
Has anybody used vulcanised fibre sheet to laminate guitar sides?
Leigh
Leigh
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid"
Re: Fibre Sheet for side lamination
Post by kiwigeo » Sat Dec 14, 2019 5:09 pm
I did a parlour guitar with laminated sides a few years back...think I used some macrocarpa side sets for the inner lamination and some extra thin Indian Rosewood side sets I got from LMI for the outer layer. I'm not sure if fibre sheet would be stiff enough to work for laminated sides.
Post by jeffhigh » Sat Dec 14, 2019 5:11 pm
Fibre sheet would probably be quite damping too
nkforster
Post by nkforster » Mon Dec 16, 2019 11:10 am
LMI sell it - its called Fish paper in the US, and gasket paper in the UK. The gasket paper I bought in Oz has a more rubbery feel and is a bit different.
If you're trying to laminate the top and back purfling into the sides you're best off buying from the UK or USA. If you just want to laminate sides, you don't need to use gasket paper.
What are you working towards? How thick do you want to laminate? Are you using double sides? Triple sides? Veneer?
