Long time no build
Re: Long time no build
Post by Mark McLean » Fri Sep 11, 2020 8:47 am
stevemc32 wrote:
Thu Sep 10, 2020 7:10 pm
So it's all done and sounding great.
Now time to finish reading the books and get the shed cleaned up for the next project. Cheers!
Happy times!
Pat.Hawkins
Post by Pat.Hawkins » Fri Sep 11, 2020 12:04 pm
On fret bending..
Trevor G has a Fret bending jig in the Jigs and Fixtures forum.
Just search there with the word emergency.
I copied it using a wooden base plate and three wooden dowels.
I realise that's only good for short-term but it worked a treat.
I padded the dowel posts with wraps of masking tape till I got the correct radius.
Hope that's of some use.
stevemc32
Post by stevemc32 » Sat Sep 12, 2020 9:14 pm
Thanks Pat, the undersize tang was definitely my problem with the first set of frets, it was not something I'd considered before.
I made a fret bender a long time ago that looks very similar to the one you mentioned but I used sliding door rollers. I don't need any sort of drive for this one, just push the wire through and hold it straight. It doesn't bend the first and last few centimetres of wire which is a bit of a pain.
Users browsing this forum: No registered users and 184 guests
