Had a nibble about bouzouki commission which would have to be shipped to the US. I haven't sent anything bigger than a mandolin overseas for several years and have no idea what might be the best option for shipping a bouzouki, likely to be in a guitar case, to America. As well, what might be current thinking on Lacey Act compliance as it would be over the US$2000 cut-off. All suggestions and/or commentary welcomed.
Graham
Shipping to America
- graham mcdonald
Shipping to America
Graham McDonald
- peter.coombe
Re: Shipping to America
I am not sure what you mean by "current thinking on Lacey Act compliance". The bottom line is you need to comply or risk getting the instrument confiscated. The painful part is the bit your US customer has to do, but it is not too onerous and so long as you use woods that have been legally logged you should be fine. I fill out the form for them with all the wood info, and they fill out and lodge the rest of the form. It is well worthwhile to make sure you don't use any shell inlay. If there is any shell then that will involve more pain than the Lacey Act requirements for your US customer.
I have only sent mandolins and mandolas to the USA, and they fit into the max package size of Australia Post. I used to use DHL, but they became ridiculously expensive so now use Aussie Post and so far so good. The last thing I sent to North America (to Canada) was a guitar that was too big for Aussie Post and I used Pack and Send who used DHL. It arrived safely and there were no problems after it left Bega, but I had some problems with pickup from Bega, and had to chase it up several times. That is fairly normal for remote rural areas. You shouldn't have that problem since you are in Canberra, and you might be able to drop it off with them.
- rocket
Sent a guitar to Alabama earlier this year Graham, used PackSend/DHL with no probs. Customer fills d in CITES/LACEY forms , package only took four days door to door
Rod
Rod
