fret slot cleaning
nkforster
fret slot cleaning
Post by nkforster » Thu Jun 10, 2021 8:38 pm
Anyone know a source of dremel/dental bits suitable for cleaning out fret slots? Other than the one Stew Mac sells which is a bit wide.
mooshalah
Re: fret slot cleaning
Post by mooshalah » Fri Jun 11, 2021 4:13 am
Hi Nigel.
You've not stated the particular method whereby you'd clean out a fret slots with a drill bit, or your particular application.
Frets tend to be cut to a width of 0.46 mm - 0.58 mm.
StewMac sells a Fret Slot Cleaning Tool that is around 0.44mm wide, and a Japanese Fret Slot Cleaning Saw that is around 0.51 mm wide. I couldn't see on their website a "dremel/dental bit" suitable for this purpose.
The smallest CNC micro drill bits that I've found that will fit into a Dremel (that I use for inlay work) have a cutter diameter of 0.8 mm.
For example https://www.ebay.com.au/p/1749165050?iid=252072281339. I think you can get cheaper.
These are pretty small; they break easily if too much lateral force is applied to them. I think I might have seen ones that are 0.7 mm diameter, but I don't have any.
I have a supply of real dentists' bits - actually diamond-coated burrs (used, and then given to me by a dentist friend!) - but the smallest of these is around 0.8 mm diameter; they're on a 1.5 mm diameter shaft, which I think might just fit into the smallest Dremel collet. I don't think that a dental equipment supply company is going to have a bit or burr much smaller than this, and if they do, it'll be expensive!.
If you think that either of the two above might be useful to you, send me a PM, and I'll send you one via mail.
Frank.
mooshalah
Post by mooshalah » Fri Jun 11, 2021 4:32 am
Whoops!
Just started idly looking on eBay, and saw these - 0.5 mm router bits.
https://www.ebay.com.au/itm/35264226633 ... Swu8dgWnoe
They appear also to have available such bits in 0.6 mm diameter.
Maybe these can work for you!
Frank
Post by kiwigeo » Sun Jun 13, 2021 6:16 pm
I use a Japanese fret cleaning saw.....simple but it does the job.
