Heelless neck joint
Heelless neck joint
Anyone got a good design for this?
I don't care for the Fender type neck plate looking for something more subtle
I'm building for my brother in law who plays lap style but not slide, with his index finger on top and thumb under the neck.
- graham mcdonald
Re: Heelless neck joint
Think about a hollow neck block, with a mortice for the end of the neck to sit in. Embed a couple of t-nuts in the top surface of the neck (covered with the fretboard) and bolt the neck the neck on from underneath. Pics of a couple of bouzouki bodies to give you an idea. The structure is glued up from bits of 8-10mm thick mahogany.
Graham McDonald
This is a poor photo but you get the general idea. I blackened the bolts as these looked too bright against the rosewood.
Here's a picture of the neck joint
There are two bolts at the other end of the mortice that are done up from inside the soundhole. That's a real pain. The next guitar will just have two bolts accessed from the back. I glued a steel washer onto the heel block in a counterbore so that the s/s allen bolts sit flush with the back once its on.
Yep, I endorse what Graham and Richard said. There is actually no need for the heel, very good reasons to eliminate it, and a number of good options to attach the neck in another way. Here is one I made following Graham’s plan, with a hollow neck block (a bouzouki style body, but you could do the same with a guitar shape).
I also love my Taylor Big Baby which has the same style of heel-less neck sitting in a pocket in the neck block. The Taylor has the neck attached by two screws straight through the fretboard at the 16th fret, which is inelegant but effective. Or you can hide the bolts inside, or come in from the back
Have you checked out the fairly new Martin SC13e
Mt ten cents worth. Alot of good practical reasons for no heel...but I'm old fashioned and like the gradual transition it creates from the body to the neck. Its aesthetics I know but if aesthetics weren't part of the equation we'd all be making carbon fibre bricks
That Martin.....it's got binding on the top but they appear to have chickened out on running binding around the bottom.
Normally I would just do the heel, but I want to do a 12 fret joint and still allow easy access for him with lap style playing with thumb under (hand injury)
Thanks for the ideas Guys
This isn’t a bolt on, I can’t seem to do my cutaways different.
Not my idea, and no pictures, but you could do a tapered sliding dovetail into what I call the neck block top plate, with a single screw accessible from inside to stop it unplugging. Fully fit the dovetail before you glue the fret board on.
My archtops have an unusual "long neck" design but there is no reason why you couldn't make this a normal length neck and attach it as I do - with 4 bolts and inserts. A round neck into a round mortise.
