Cello build
- rocket
Cello build
So i've been in this caper for about 13 years now and after building a pretty average violin to begin with decided to diverge a bit to arch top guitars and there i've been content and had quite a bit of success and starting to be recognised in some circles but felt i needed to expand a little so i've decided to have a go at a cello. As you can appreciate this is not a folly as the timber needed to build one of these is very expensive , anyways i intend to post the progress of this build on here and share my frustrations and elations,,,, to be continued.......
Cheers Rod
Cheers Rod
- rocket
Re: Cello build
The cello i'm building is a copy of a 1739 instrument titled, "Sleeping Beauty" by Italian master luthier, Domenico Montagnana who was based in Venice. I've been loaned some plans and have started making some patterns. I will be using Australian Otways Blackwood for the back and sides, supplied by Kidman tonewoods, the belly will be European Spruce, yet to be sourced, but not in a rush for that!.
This project is an indulgence really so it'll be sidelined if a guitar commission pops up so this might take a while!!
Re: Cello build
Look forward to it Rod.
I've always thought that the carving of either archtop guitars or the violin family requires so much more craftsmanship than a straight guitar build. I'm not going there. Enough trying to get a 'straight' build right. But will enjoy seeing how you get on.
Cheers Dave
Cheers Dave
- rocket
Re: Cello build
Thanks Dave,,,
So i've got the inside form nearly ready to go , the next step is fitting the tail, neck and corner blocks....
- IMG_7408.JPG (115.63 KiB) Viewed 6828 times
- IMG_7407.JPG (98.23 KiB) Viewed 6828 times
- 24D861D6-7156-4F32-A506-6ED53E339A54.JPG (119.38 KiB) Viewed 6828 times
- rocket
Re: Cello build
Here's a couple of pics showing the corner blocks being shaped in the C bout.
Rod,
Rod,
Re: Cello build
Following!
- rocket
Re: Cello build
Yes the blocks are Spruce Dave.
I've put this on the back burner for a little while the reason being is that i planned on using some nice Otways Blackwood for back and sides, i've resawn the timber into back set and sides but the back is still a little high in moisture content but the sides are just about there.
Meanwhile i've dug another mandolin project out of mothballs while i'm waiting and continuing with that, also we're off to Europe in a few weeks so not in any rush on the cello build atm but will certainly post any progress as soon as there is any! Thanks for looking..
Rod
Rod
Users browsing this forum: No registered users and 179 guests
