Explained in the link contained in the first post: http://forum.ukuleleunderground.com/sho ... 0+problemspryseguitars wrote:I just bought myself one of these second hand. Can someone tell me what the actual problem part is? I haven't had a chance to use it yet but don't want it to break when I do. Thanks.
Here's a video I made ...https://www.youtube.com/watch?v=RsmnY8dCODANick wrote: ↑Mon Oct 13, 2014 6:43 amNice fix Ken![]()
Most machine tools use a split nut on leadscrews to handle just such the problem you encountered with the 'loose' thread and elegant fix. Because they are a high wear item you need some form of adjustment to eliminate wear/backlash.
Classic example for everybody of why you should keep a little bit of grease up to threads, galling of the thread is the biggest killer of tapped aluminium threads, it only needs the tiniest of aluminium or other 'solid' particle to pick up and it begins to bugger the whole thread.
