Having bought a deceased makers stash of Indian Rosewood I couldn't resist setting to straightaway with my now fairly settled classical design. The tops are Engelmann. The Rosewood is certainly pretty.
Cheers Dave
Duo becomes a Trio
Re: Duo becomes a Trio
It looks lovely Dave. Great execution with the binding and purfling design and the overall aesthetic. So - how much difference in sound between the maple and the rosewood guitars?
Thanks Mark, as you can see I used different styles with the Maple, Walnut and Rosewood. The rosettes are commercial except for the ‘fan’ since I am unwilling at this point to expend the time to do a traditional version.
The latest, the Rosewood I think is the best I have made. I am however reluctant to ascribe it to the timbers.
I have been using a Torres fan bracing (based on SE114) for all of them but have been slightly reducing the size on each one. The last, the Rosewood, I did more scalloping so the overall stiffness was that little bit lower. A bridge rotation test a la Trevor showed almost bang on 2 degrees so I think I have the right mobility of the top.
However given the complexity of the subject I am not going to say anything definite!
I intend to do a proper analysis of the three, establishing the main resonances etc and maybe that will provide more info on the different back and sides material
A little more work on set up is needed but they are all really nice to play.
Cheers Davel
Cheers Davel
- lamanoditrento
Very nice. Nice looking finish and lovely continuous heelcap/cutaway purfling line
- WJ Guitars
Thanks Wayne, Trent.
As you will know getting the line on the heel to line up properly with the purfling is tricky. With these I was pleased.
