Les Paul Junior Build
asgilbert
Post by asgilbert » Thu Mar 09, 2023 4:01 pm
Hi all, My recently finished Les Paul Junior with P90's by Mick Brierley. Body and neck are Mahogany. Mahodany blank for the body kindly given to me by a mate in Albany. The fret board and headplate are Ebony. Schaller gear all over.
Re: Les Paul Junior Build
Post by ozziebluesman » Thu Mar 09, 2023 4:17 pm
Beautiful job. Love the guitar especially the block, neck inlay.
Any secrets on your method of inlaying/
Thanks for posting.
asgilbert
Post by asgilbert » Thu Mar 09, 2023 4:40 pm
Thanks Alan, Just the usual mark out with sharp knife, rub over with chalk to get the line to show up well. Then use a 1mm bit in a Dremel to get as close as possible to the line and finish off with a sharp chisel. I have a 14' rad on the FB so it is not too bad but next time I will use a thicker MOP so it looks less translucent on the sides. Most of it is ok... just a few have that translucent look where the radius of the FB means you remove material at the ends of the inserts.
WJ Guitars
Post by WJ Guitars » Fri Mar 10, 2023 7:45 am
Excellent electric guitar build!
Mr K
Post by Mr K » Fri Mar 10, 2023 3:35 pm
Loverly build, and some nice Mahogany. Mick's pickups are great have a few sets myself.
Post by Taffy Evans » Fri Mar 10, 2023 5:26 pm
Hi, that’s a guitar I really like, and yours looks great. I supported my grandson to build one some years ago.
